This is a sticky topic.
E30 325i Touring currently under construction.
http://www.r3vlimited.com/board/show...256444&page=20
sigpic -
You'll need 15-20mm spacers to fit those properly. I'd suggest 15mm front 20mm rear. 205/50 is a suitable size, as is 205/55.Comment
Need to know if it will fit...
16x8 BBS RS et23 (4x100) with 225/45/16 on a stock suspension 89 vert. If so can I push it to 235?
I am planning for a GroundControl coil-over kit in the near future...Life is a bitch and then you drive.
- Kaotik_LifeComment
Yes, custom... Went with 16x8 front and 16x9 rear with et13 all around. Did the SL lip in the rear and NR lip in the front. Essentially more lip in the rear. I am looking to a bit of a stretch. Nothing extreme.Comment
Front: 16x8 et20 205/50R16
Rear: 16x9 et15 225/45R16Comment
Fronts will be paper-thin clearance to the struts. You may need a 3-5mm spacer depending on tire bulge. Rear fenders will require a roll. There are no 235 16" tires.Comment
You can go with any of the following but again, check and see tire availability before you think you've figured it out:
205/50 F 215/45 R
195/50 F 215/45 R
195/45 F 215/40 RComment
3-5mm front spacer, and I'd switch to a 215/40 front (less dangerous, gives you more ground clearance and load rating than the tiny 205/40s).Comment
16x7
et 22
88 325 lowered on ground control
I think 215/45 is ideal but can I fit 215/50 without modification ?
thanks again for all your help
Sent from my ADR6400L using Tapatalk 298 M3/4/5
