This is a sticky topic.
I'm trying to figure out if this will ever work
16x8 et25 rears
16x7 et13 fronts
18mm adapters f/r
early arches, not rolled yet but could be
what's the meatiest tire size I can go? I'm worried about the fronts sticking out too far, but I have some camber adjustment to play with.Comment
aw, 195 is pretty wimpy :(
I'm not 100% about the wheel measurements, will remeasure them tonight, the seller wasn't sure about the numbers he gave me.
What effective offset do I want on the fronts to have them flush without -3.5 camber? something more in the 2 degree range would be more preferable, and the wheels have a bit of room to get skimmed.Comment
i'm not 100% about the wheel measurements, will remeasure them tonight, the seller wasn't sure about the numbers he gave me.
What effective offset do i want on the fronts to have them flush without -3.5 camber? Something more in the 2 degree range would be more preferable, and the wheels have a bit of room to get skimmed.Comment
Need help, I have 17x8 et20 and 17x9 et25 . What tires would you recommend , it's an m technic so it's lowered . ThanksComment
15x9.5 et -5. How much poke am i looking at outside stock fenders, just for comparison. I know ill need to roll, but im thinking about a slight pull if they poke too much. Also what size tire works well with that. I want stretch to keep the tires inside the fender, but i dont want anything too ridiculous. Also, i am running about -6 degrees of camber in the rear
INSTAGRAM @ merlow_
16x8 F 16x9 R
Trying to find correct size tire for my 16x8 ET15 (front) and 16x9 ET20 (rear) would 225/45/16 all around tires fit with rears rolled?Comment
15x9.5 et -5. How much poke am i looking at outside stock fenders, just for comparison. I know ill need to roll, but im thinking about a slight pull if they poke too much. Also what size tire works well with that. I want stretch to keep the tires inside the fender, but i dont want anything too ridiculous. Also, i am running about -6 degrees of camber in the rearComment
