	This is a sticky topic.
 No rolling the fronts.Comment
 exactly, z06 wheels. I've got a 325i sitting in my garage, and .... yah ummm lets see... Anywhos, ive got a thought I wanted to run by you about wheel offset and get your input.
 ...if the wheel offset is very different from stock, would that cause unneccessary axial loading of wheel bearings? causing unwanted thrust forces which increase rolling resistance and also reduce bearing life? I don't have a source or anything on this just something I was thinking and wanted to see if you (or others) think the same.Comment
 Noob to tire staggering here......OK doing a suspension upgrade.. i have a set of 215/50/16 in the fronts that have less than 200 miles on them so obviously no need to replace these and i don't want to buy a brand new set of 4.. So what size would be a good call for the rear for a good staggersigpic"God made cars to be RWD and standard"Comment
 Suspension on the car
 KW 60/40 lowering springs with kw struts and shocks.
 Wheels
 15x8 offset 19
 Will 225/50/15 fit with out having to roll or pull fenders?
 I can't decide if I should run all season
 225/50/15 or Summer tires in 205/50/15
 Money is keeping me from 225/45/15I'm cooler in person.Comment
 Spacing out wheels does add extra stress on wheel bearings.exactly, z06 wheels. I've got a 325i sitting in my garage, and .... yah ummm lets see... Anywhos, ive got a thought I wanted to run by you about wheel offset and get your input.
 Originally posted by SpasticDwarf;n6449866Honestly I built it just to have a place to sit and listen to Hotline Bling on repeat.Comment
 It's funny. I just bought a set of those same wheels, that's why I knew the dimensions so quickly. Picking them up Saturday.exactly, z06 wheels. I've got a 325i sitting in my garage, and .... yah ummm lets see... Anywhos, ive got a thought I wanted to run by you about wheel offset and get your input.
 If the geometry ends up the same I'm one to believe the load on the axle/hub/etc remains the same. For example a +35 wheel with a 15mm spacer does NOT provide any additional stress than a +20 wheel. I've read every argument for both sides and stay firmly planted in this camp.Comment
 There isn't. The fronts are already oversized in diameter, there's no suitable rear that will look right and actually fit.Noob to tire staggering here......OK doing a suspension upgrade.. i have a set of 215/50/16 in the fronts that have less than 200 miles on them so obviously no need to replace these and i don't want to buy a brand new set of 4.. So what size would be a good call for the rear for a good staggerComment
 Roll 100% needed. Use 205/50s.Suspension on the car
 Wheels
 15x8 offset 19
 Money is keeping me from 225/45/15Comment
 Hey, need your help again. The wheel is 17x8.5 et 13 5x120
 What tire spacer combo do I need to fit?My old Style 5 Thread / My Swap
 1991 318IS :bow: 2.5L S14 Swap/BC Coilover suspension/Some new (old) wheels/
 IS Skirt-Lip/RG Splitter/M-Technic I Spoiler/Dogleg/3.46 Diff/Euro H4 headlights etc.
 1998 528I (Sold) // 2003 540I ///M SportComment
 Car is soon to be lowered on FA coilovers so I've been wheel shopping..
 16x8 et12 and 16x9 et12
 What tire sizes should I run? I'd like to stick with a very mild stretch. Also will it take much fender work to make them fit?sigpicComment
