	This is a sticky topic.
 Mike
 Cary, NC
 Current Rides
 1991 325iC - For Sale
 2006 M3 Cabriolet
 Past Rides
 2000 323i Touring - Daily Driver
 1994 325is (S50) - Fast Car
 1998 Z3 - Fun Car
 1986 325e (i engine conversion)
 1969 Mustang Mach 1Comment
 good luck with that. I am barely fitting 9.5j epsilons in the rear with a 225/45 tire. Going to need like 4 inch wide over fenders to get them to tuck in.2014 Alpine White 335i MSport
 (Daily Driver)
 Full Mperformance Aero
 KW V2 Coilovers
 VRSF Catless DownpipesComment
 thanks never went with the wheels, down sized to a 16x8 et25, now looking for tires, thinking 215/40/ or ? have to check the tires sites, thanks for the help,88 M3 Lachsliber glass top, 90 IS project,Comment
 17x8.5 +30 is ideal for the rear. 245/40s will work with a roll and stiff enough suspension.Maybe this will be easier with an end goal given so its not a guessing game for me. lol.
 So the end goal is to fit a 235/40 or 245/40 wide tire in the rear without running flares (preferably 245). Obviously with 17's the tire choices are much better.
 So if I go to 17, I need an 8-8.5 wide wheel. What would you say is the correct offset for them? Was thinking 17x8 et25(235 tire) and if 17x8.5 et30(235 or hopefully 245)?Comment
 If those offsets are negative then you don't need to worry about in the inside at all. It's the fact the wheels are way outside of the car. The offsets are just wrong for an E30, about 10mm too aggressive to work.I have idea to buy R16 8,5j and 9,5j rims to my 90 318i euro model, back will be 9,5j with -6 et, front 8,5 with -10 et.205/45 rear, 195/45 front, camber plates, stiff suspension, not so low at this moment. Will my rear fit without hitting shock and any other things inside? What about rubbing?Comment
 Did you buy them? It's a long answer but only if you're dead serious here.Comment
 I think it's too aggressive still.Hi! First, thanks for all the advice you are giving! Pretty awesome!
 Wanted to fit 15x8 et20 With 225/45/15 G-Force Rival or Ventus RS3... I know that it fits. BUT, I could have access to a nice deal on 15x8 et0 with 225/45/15 Ventus RS3. I know its impossible on stock fenders, but my fenders are rolled and pulled and I shaved a bit of the interior exceeding sheet metal... For reference, Here is the status of the rear fenders on my 89 325ì with 17x10 et20:
 Also, this is where the 235/40/17 Toyo RA1 (which runs pretty wide) contact the fender (on the 17x10):
 So do you think its near possible or I should forget it right away?
 I know that funfgan is running 15x8 et5 final with RS3... but 5mm can do a big difference...
 Thanks again!
 Note that front is also rolled and pulled...Comment
 If the wheels are not hubcentric there's a very strong chance you will get vibrations. It's not a balancing issue per se.Does hub bore size difference cause improper balancing?
 the reason why I ask, is because I recently put a set of steel 14 inch stock e30 wheels and tires on my e30 and it rides and steers like a DREAM!!! Never since I've owned this car has it performed so smoothly and quietly (could also be the tires helping too).
 Those wheels are Borbet type C's and while they look nice and all, I really want to go to a smaller wheel size.
 Any wheels being made new that have the same 57.1mm centre bore and are 4x100 and 15 inch?
 thanks in advanceComment
 Yes, they will just fit. If your front fender liners are loose (or you get offset front control arm bushings) you might scrub them a bit at full lock but nothing serious. 195/60 and 195/55 both work fine also.Suspension:
 H&R Sport Springs (for Cabrio) Average lowering of 1.4"F, 0.75"R
 Rim Info:
 Konig Rewind
 Diameter 15.0”
 Width 7.0”
 Offset 20mm
 Tire Size Options
 1. 205/60 - 15 (seem to be more avail in this size)
 2. 205/55 - 15 (not many avail in this size)
 Not looking for a track car - but a sporty daily driver. Will the 205/60s fit? Recommendations for tires? Are there other options I should consider?
 Thanks in advance for your dedication to this thread.Comment
 Won't fit properly in front. 205/50, 205/45, 215/45, 225/45.Comment
