This is a sticky topic.
  • NeedaE30
    • 397
    #6676
    i need some help guys..
    just bought some 15x6" et33 BBS RA's.. my stock lug bolts are not long enough to mount these wheels even without spacers... i want to end up running atleast a 10 mm spacer with these wheels... can i get a set of extended lug bolts that will work with and without spacers? and if so what length should i get? i am in desperate need to get these wheels & tires mounted as the tires on my bottle caps will probably blow any day now, hopefully not while me and my daughter are on the highway...
    • saturnv7890
      • Jan 2011
      • 696
      #6677
      on a 16x8 et0 (sportmax) does anyone have a comparison of 195/45/16 vs 205/45/16?
      I love a small stretch, I'm considering going staggered. Any pictures/input is much appreciated!
      My Transaction Feedback
      My "build" thread
      BUY MY CAR!!
      • saturnv7890
        • Jan 2011
        • 696
        #6678
        And to try and help, motorsport hardware is incredibly helpful and supportive of their products, they responded to a question I had really fast. They might know something about this
        My "build" thread
        BUY MY CAR!!
        • Tismael711
          • 791
          #6679
          would i have a problem running bbs rs012 16x7 et23 / bbs rs014 16x9 et11 on my e30 if i had them filled and drilled to 4x100? they are originally porsche fitment 5x130.
          • NeedaE30
            • 397
            #6680
            So, if anyone has mounted 15x6" et33 BBS RA's off of a MKII GLI on an e30. please let me know what size/length lug bolts you used? with or without spacers.. i need this info and obviously i'm too stupid to figure it out lol
            • Mystikal
              Wheel Fitment Expert
              • 9602
              #6681
              Originally posted by LowR3V'in
              Mystikal: Have you seen a wheel combo that you can fit 275 or the likes
              with some fender rolling?
              I'm looking at 15/16x9 et.25
              I have not.
              • Mystikal
                • 9602
                #6682
                Originally posted by e30lyf
                what's the ideal tire size on these? thanks again
                I'd go for fitment and stretch them to 195/45 and 205/45, personally. That's a little extreme for some.
                • Mystikal
                  • 9602
                  #6683
                  No, if the bolt is the right length to work without spacers then they wouldn't work with them.
                  • Mystikal
                    • 9602
                    #6684
                    No problem. You'll likely end up with 15-25mm front spacers to match the rear fitment.
                    • blck325is
                      • Apr 2006
                      • 1749
                      #6685
                      I have a 1990, 4dr e30 on HR's and Bilsteins all around. I would like to run a set of diamond racing wheels in 16x8.
                      First, what offset will I need to clear everything and get them flush?
                      Second, how much tire can I stuff in there if I roll the fenders pretty flat?
                      Third, I know they aren't hubcentric so can I get hubcentric rings to help with this?
                      Originally posted by csermonet47
                      Vlad, you are handling this quite unprofessionally.
                      Also, you are a cock with tacky taste.
                      That is all.
                      • Mystikal
                        • 9602
                        #6686
                        There are oddities regarding both brake caliper clearance and hub centering with the Diamond steelies that I'm not entirely familiar with. I'd search the forum for more info.
                        • blck325is
                          • Apr 2006
                          • 1749
                          #6687
                          I will figure out the hub centering but the I looked around on the brake caliper clearance and found a few things.So far I've seen some people getting +12 offset on all 4 corners and running a either a 5mm spacer and grinding the caliper bracket off, or adding a 12mm spacer and leaving it alone. I think I will do the +12 offset and 12mm spacers for the front atleast.
                          Last question, with the 16x8 +12 offset and 12mm spacer (fronts probably, backs if necessary) what is the maximum tire I can squeeze in there?
                          That is all.
                          • CGY_GTI
                            • Jul 2013
                            • 7
                            #6688
                            Hey everyone,
                            I have a new set of wheels on the way for my new-to-me '88 325i, lowered on H&R springs. They're 16x7" and 16x8" BBS RS (not sure which model exactly) - et33 with 195/50R16. I might switch out the tires for the 205/50R16s that I already have over the winter when I refinish the wheels.
                            So my question... will I have any rubbing issues with this setup? If I will, what size spacers should I go with to avoid having to roll my fenders.
                            Thanks in advance!
                            '16 Volkswagen Golf R | 6-speed | Oryx White Pearl | Titan Black Leather | Tech Package
                            '88 BMW 325 | 5-speed | Bronzitbeige Metallic | Natur Sport Leather | M20B25 swap | 3.73 LSD - Gone
                            • Mystikal
                              • 9602
                              #6689
                              I wouldn't do that. 0 offset 16x8s poke outside of the fenders in a bad way unless you're running very, very aggressive camber. 195s are your limit.
                              • Mystikal
                                • 9602
                                #6690
                                Originally posted by CGY_GTI
                                Hey everyone,
                                Thanks in advance!
                                You'll want 15mm spacers all around. Should just clear without rolling in the rear.
