This is a sticky topic.
You'll need a template (usually a .pdf) from the brake manufacturer to know for sure what fits.Comment
It's possible with a 195/45 or 205/40 and a flat fender roll all around. May need additional front camber (plates, crash mounts) if you're very low.Comment
At a guess I would say they would get pushed way out of the arches when using adapter as they normally are quite thick (20-25mm?).
Anyone run 16x9 et15 with 225/45/16's? Looking at a tyre size calc these are close to stock 205/55/15's. I can do what ever work is required before resprayComment
16x8 +20
205/50 or
215/45 or
225/45Comment
245/40-17 or 235/40-17 on a 17x8.25 with ET20.
E30 M3 Front/rear fiberglass quarters. Possible? I can "space" the rear fender out if I need to. I know I'm running into the issue of the tires being oversized (diameter), but it's a track/drift car. What size spacer would you recommend, if any?Comment
I am looking into rubber for a set of wheels I have. I do not know what is a proper tire size that is good with the s50, any ideas? Wheels are 16x7 et37 and I'll be running 10mm spacer front and rear. Also I don't know how far the wheels will sit, anyone have a close setup that I can see photos of? Thanks in advance, my wheel/tire knowledge isn't great
Patrick - IG:niicknac
RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, baggedComment
I am looking into rubber for a set of wheels I have. I do not know what is a proper tire size that is good with the s50, any ideas? Wheels are 16x7 et37 and I'll be running 10mm spacer front and rear. Also I don't know how far the wheels will sit, anyone have a close setup that I can see photos of? Thanks in advance, my wheel/tire knowledge isn't greatComment
