This is a sticky topic.
I have a 87 325e, 1.5" drop using bilstein sports and eibach springs.
Will these wheels fit? Or is the offset completely wrong?
http://www.ebay.com/itm/4-16-INCH-WH...p2054897.l4276Comment
Dear wheel fitment gods, here is what I have:
Fr - 17x7.5 et38
Rr - 17x8 et20
Im doing a turbo build at the moment and want as much rubber as I can get on the ground. What am I looking at as far as tire size and spacers needed? Im lowered on Billies and BavAuto springs (probably Eibach). I'm all stock other than M3 offset CAB up front. I am fine with rolling the/mild pull, just nothing crazy. I'm also not interested in dumped/hella flush.
THANKS IN ADVANCE!Comment
I am very lazy and do not what to go through 400 pages to find my specs. Though these are pretty common and I'm sure they are only a couple pages back. Then again I am lazy.
16x9 et20 stock suspension. What tires should I run? I don't want to stretch. Normal size will be fine for me. Thanks again for your services.Comment
Does anyone know the lowest offset I can go on TRM C1 15x7 with 205/50 tires, I have a moderate drop and the current ET is 25
EDIT: with no fender modification/rolling
image (10) by serdar.gurhan, on Flickr
PM me for custom shift knobs and stickers!
Originally posted by marshallnoiseYou ain't done working on a car unless you are bleeding.Comment
Last question I promise.
If this guy can fit 15x9 et 4 with 225/50 all around, I should be able to fit 15x9 et10 with 225/45 all around right?
Obviously I will need to do some rolling/pulling
Your setup is on the ragged edge of what works, but it's possible if you're not too low.Comment
Fr - 17x7.5 et38
Rr - 17x8 et20
THANKS IN ADVANCE!
That said, with a 15mm front spacer and 215/40s all around that is still a solid setup if you buy the right tires.Comment
Funny enough the wheel company contacted me. They ended up having the original size I wanted. So now the question is what tires for 16x8 et25 all around?Comment
