This is a sticky topic.
  • bmwcalvin
    • Jan 2010
    • 424
    #5521
    Couldn't find it anywhere so...
    17x8 et22
    What size spacers if needed?
    Originally posted by IRON-E
    Skirtz are for zeh womenzzzz....
    • LrgSoup
      • Mar 2012
      • 22
      #5522
      Originally posted by Mystikal
      That straight up does not fit an E30.
      Lol, for sure. I am looking for a flush set up (not hella flush!). Semi stretched tires. What would you recommend for as much lip as possible without super stretched tires with a 9" wide wheel? Front and rear? Thanks!
      • mulletman
        • May 2012
        • 801
        #5523
        Question:
        Vehicle is a late-model 325is...
        Looking at wheels that are 15x8 et15. I hate the stretched tire look... going for the beefcake tire look instead. Car will be lowered somewhere near the height of H&R Race springs. I'm willing to do some fender rolling, but I'd rather not start pulling. Non-staggered (square) setup.
        Could I get a 225/50 to work? If not, what tires would work? Would I be better off going with a 16x8 et20? Prefer the 15's...
        Thank you in advance.
        • madsedan
          • 222
          #5524
          Staggered set of wheels I found locally, onto my 91 318is....
          16x9 et 15 out back and 16x7.5 et 35 for the front
          '91 318is, S50 swap, Bilsteing/H&R race, Recaro SRD, etc.
          • Eydreeyun
            • 584
            #5525
            Originally posted by Eydreeyun
            e36 m3 suspension/318ti rear
            Wheels: 16x8.5 et39 & 16x9.5 et 27
            Fenders are rolled and on BC coilovers 550/650
            Would 205/45/16 front 225/40/16 work?
            Any spacer should I use?
            With pulled rear arches, yes. No spacers hopefully, you might need something small for the fronts but I can't say for sure.
            How about 16x8 et 45 & 16x9.5 et 27
            Tires: 205/45 front 215/45 in the back, Still on e36 m3 suspension
            How's the rear going to look?
            • Mystikal
              Wheel Fitment Expert
              • 9602
              #5526
              Originally posted by alfie
              i want to run xxr 531 16x8 et0 an i was hoping to run a 225 45 16 is that possible? would you say its a bit extreme for a daily? i drive a late model sedan and am willing to do fender work if need be. thanks for the help.
              Not even close. Stay away from 0 offset wheels, to run 225s you need +20 or higher.
              • Mystikal
                • 9602
                #5527
                Originally posted by pyrofire127
                Thanks for the quick reply!!
                Yeah I'm doing the Rx7 brake swap and didn't want to grind it down too much, I'll see if they are really needed once i get it all put on.
                But also ESM says for the 002R the stock brakes either have to grind them a little or run 5mm spacers. and maybe a set on the back to level it out?
                Can i fit anything bigger than that? like a 215/45, 205/50 or 215/50? Where do you think i would hit my limit with the stock fenders?
                225/45 fits no problem with a rear fender roll. If you're after grip then 205/50 Dunlop Z1 or 215/45 Kumho XS.
                • Mystikal
                  • 9602
                  #5528
                  Originally posted by gnarlycreature
                  Im on kw v2's
                  * 3-piece Schmidt Revolution Modern Line wheels
                  * 16x9
                  * Staggered ET 21 Front, ET 8 Rear
                  * Toyo Proxies T1-S 215-40-16 all around.
                  * VERY LOW
                  You suggested 10-12mm spacers for the front. Is this the most aggressive I can run?
                  What do you recommend for the rear?
                  Yes, even when front 16x9s are hugging the struts as the 10-12mm spacer will do they poke out the fenders slightly. No more spacing. For the rears you may want to add a 5mm later if you roll the fenders well and want that little bit more.
                  • Mystikal
                    • 9602
                    #5529
                    17x8 et22
                    No spacers that's damn ideal. 215/40 all around without rolling, 235/40 all around with just a rear roll.
                    • Mystikal
                      • 9602
                      #5530
                      You pretty much have to stretch tires to fit a 9" wheel on an E30. My most commonly suggested tire for a 9" wheel is 205/45 on 16x9 (perfect fitment IMO). Not a crazy bead-showing stretch but still very noticeable.
                      • Mystikal
                        • 9602
                        #5531
                        Originally posted by mulletman
                        Question:
                        You'll be limited to 205/50 realistically. 225/50 would be extremely aggressive and likely wouldn't work without pulling. 225/45 has a damn good chance though now that I think about it more.
                        16x8 +20 on the other hand is ideal. 225/45 all day long.
                        • Mystikal
                          • 9602
                          #5532
                          Sound like Borbets. Needs at least a 20mm front spacer to fit properly, I'd actually suggest a 25mm bolt-on type if budget allows. 195/45 F 205/45 R.
                          • Mystikal
                            • 9602
                            #5533
                            The rears will be poking while the fronts will be sunken way in. If you're subtracting lips that's the opposite of your problem, it's the inner barrel that's too large.
                            • mulletman
                              • May 2012
                              • 801
                              #5534
                              Ah, so that extra 5mm is too much? Dang. Thanks for the reply.
                              How much pulling would be required? Front or rear, or both? Tires would likely be Falken 912's, if that helps. I seem to remember reading that some Falken tires run a bit small for their labeled size... although I have no first-hand knowledge.
                              • Tech2bmw
                                • 17
                                #5535
                                Hi, new to this forum. Wheel specs are: 15x8.0, et12 (front) and 15x8.5, et6 (rear). Would 205/50/15 be ok and will the guards require rolling? Any advice will be appreciated. Thanks
