This is a sticky topic.
  • e30james325
    • 202
    #7171
    Originally posted by Mystikal
    Those fit best with 20mm spacers and 195/55 tires. 195/50 is a little short. That said, as they are they will bolt up and roll - just look odd.
    MSW produced wheels mostly sold through Tirerack in the 80s/90s. European heritage I'm pretty sure. Any laying around are now OLD though.
    thank you so much Mystikal! :-D
    • Raven Tooth
      • 130
      #7172
      Looking for 16s for my car slightly lowered on H&R sport suspension. What width/ offset is recommended? Would like to avoid steering problems/ rubbing issues.
      What tire size?
      Was looking at these: http://www.ebay.com/itm/MRR-FF3-16X8...e818a3&vxp=mtr
      • Mystikal
        Wheel Fitment Expert
        • 9602
        #7173
        What tire size?
        In general most wheels up to 8" wide work well in a +15 to +25 offset.
        For those 16x8s, you will need 3mm front spacers and either 205/45 or 205/50 tires. No rubbing or rolling.
        • Raven Tooth
          • 130
          #7174
          Ok, slight update. Going to pick up some used 16x8s et15 with 225/45r16 tires on them.
          How should I expect those to fit?
          P.S. You're awesome.
          • BoxDriver86
            • Jul 2009
            • 912
            #7175
            205/45 front 225/40 rear. Or 215/45 rear in a pinch.
            Awesome. Only tire I could find is the Toyo T1Rin 225/40 and I could only find one in the country. All the 215/45 that I can find are super wide shoulder tires like the 615k or the ASX.
            Guess I need to order tires from across the pond. Sigh.
            • Edirtyy808
              • Apr 2012
              • 297
              #7176
              17x9 et35 will this clear the front struts? if not what size spacer should i get?
              17x10 et20 for the rear will be okay?
              • Mystikal
                • 9602
                #7177
                No, they will rub quite a bit. 205/45 is the preferred size.
                • Mystikal
                  • 9602
                  #7178
                  20mm front spacers should leave you paper-thin clearance and work with a stretched tire. Rears will bolt up as is, with the same tight clearance as the fronts (with the trailing arm this time). I'd use 205/40 225/35 tires.
                  • kbdrake07
                    • Jun 2011
                    • 103
                    #7179
                    I just bought a set of xxr 531 wheels for my 90 325i thay are 16x8 et20 and I run pritty low on coil overs (2in sectioned tubes) and willing to roll fenders what are my tire options .. I would love to do 225/50/16 but not sure if thats to wide.. ps will soon be auto cross car
                    Sent from my SCH-I535 using Tapatalk
                    • kbdrake07
                      • Jun 2011
                      • 103
                      #7180
                      Also if I need spacers I am open to that as well .. and I have GE coil overs and Also if its different sizes up front than back is ok too
                      • Pdxseth
                        • May 2012
                        • 3124
                        #7181
                        Will 205/55 fit on 15x9 +10 (early model)?
                        • JMAL
                          • May 2013
                          • 312
                          #7182
                          Im am wondering if i can fit these wheels/tires with out fender rub. I havent been able to find a clear answer for this combo
                          BC coilovers 88 iS not tucking, very little wheel well gap.
                          205 55 15 tires on:
                          15x8 et25
                          and/or
                          15x8 et20
                          or stick with
                          15x7 et25
                          1987 325iC/5 Alpine White/Cardinal
                          1988 325iS Lachssilber/Natur
                          • Mystikal
                            • 9602
                            #7183
                            225/45/16 fits with a fender roll.
                            • Mystikal
                              • 9602
                              #7184
                              No, 205/50.
                              • Mystikal
                                • 9602
                                #7185
                                205 55 15 tires on:
                                15x8 et25
                                and/or
                                15x8 et20
                                or stick with
                                15x7 et25
                                First ones need 3-5mm front spacers. Otherwise that tire size works on all.
