This is a sticky topic.
  • MTD
    • Nov 2015
    • 112
    #8671
    Originally posted by Mystikal
    Needs 3-5mm front spacers to clear. 205/45s all around is smart, you can also go up to 215/45 in the rear if you want. 205/55 has zero chance.
    Thanks! If i squared the 16x9 et 20 all around do you think it would still need spacers?
    Also, spacers, are they recommended? If i could avoid them i would prefer it
    • Mystikal
      Wheel Fitment Expert
      • 9602
      #8672
      16x9s make the issue worse. Spacers are perfectly safe, go 3mm to ensure no vibrations.
      • MTD
        • Nov 2015
        • 112
        #8673
        Thanks, you da man! :)
        the spacers would be something like this right? http://www.amazon.com/4x100-UberTech.../dp/B00DNND56M
        Also, in terms of fenders i am in the clear? No rolling needed?
        • Mystikal
          • 9602
          #8674
          Yeah those are perfect. You can re-use your stock bolts too. 100% no rolling with 205/45s all around, might need a little work for 215/45 if it's loaded up with weight.
          • MTD
            • Nov 2015
            • 112
            #8675
            Yeah i'm gonna go with 205/45's
            Thanks so much, you helped me a lot! A fender roller is really hard to get by in my country, i only found one shop that has one, and it's in another city, so i really would like to avoid rolling.
            PS: the spacers i sent you previously don't ship to my country, i'll have to go with these: http://www.ebay.com/itm/2-x-3mm-Hubc...gAAOSw7I5Ts-9p
            Still work the same right?
            • e30onBBSs
              • Dec 2014
              • 1347
              #8676
              5x114
              16x7 16x8
              Et45 all around
              New 165 40 16 tires.
              1200$
              Comes with 42 draft designs adapters to 4x100
              fit or no?
              BMW tech
              Umass Amherst
              05 wrx sti
              • DER E30
                • Sep 2013
                • 2343
                #8677
                Originally posted by e30onBBSs
                http://nh.craigslist.org/wto/5370867630.html
                5x114
                16x7 16x8
                Et45 all around
                1200$
                fit or no?
                I was thinking that 165 tires would look stupid, pics did not disappoint! Doesn't say how big the adaptors are, depending on final offsets it's gonna look really dumb.
                -Christian
                • e30onBBSs
                  • Dec 2014
                  • 1347
                  #8678
                  Yes lol the tires would be gone ASAP if I got them, I know my car would work mint with 16x8 and 16x7 staggered because I had 16x8's on it square and it just barely rubbed in the front, with about twice as much tire. The adapters are relatively thin I will post a link
                  High performance parts made in the USA including exhaust systems, air intake systems, wheel spacers, wheel adapters, oil catch cans, and more.
                  It would be too much + offset right?
                  BMW tech
                  Umass Amherst
                  05 wrx sti
                  • JMikesell
                    • Oct 2015
                    • 16
                    #8679
                    I'm sure its been answered,but I'll ask. I picked up some ESM 16x8et20 and am leaning toward 225/50, will the wheel extend farther than the rubber? Also, I'm debating buying some voghtlands with a 2" drop, if I do, will I need to roll my fenders?
                    • Mystikal
                      • 9602
                      #8680
                      And I complain about being a Canadian car enthusiast (maybe 10-20% of stuff isn't available here). 205/45s should work well for you. Those black spacers are also fine.
                      • Mystikal
                        • 9602
                        #8681
                        5x114
                        16x7 16x8
                        Et45 all around
                        1200$
                        fit or no?
                        Depends on the adapter thickness. If they're on a MK1 the adapters might not be thick enough for E30 fitment.
                        • Mystikal
                          • 9602
                          #8682
                          Straight up don't fit. 205/50, 215/45, 225/45. Fender roll for the last one.
                          • Shftr8
                            • Aug 2014
                            • 530
                            #8683
                            there is to much info to sort through on here lol. Sorry if its be asked before but any chance this set up will work and not rub? I believe Im running 205/55/15 now and would like to switch the tires over if I can
                            car: 89 325i on bavauto spring (1 1/4 drop) and E90 drop hats up front
                            Wheels: 15X7 et12 all the way around
                            • efficient
                              • Feb 2012
                              • 3312
                              #8684
                              ^that doesn't rub at all. I'm running 15x7 +12or +15 on 205/50/15. Lowered on lowtec 60/50 springs. Non rolled fenders.
                              • MTD
                                • Nov 2015
                                • 112
                                #8685
                                Sorry to bother again, but could i add e90 drop hats to my setup to lower the front a bit more, and still fit ?
