This is a sticky topic.
  • Jb325is
    • 2137
    #7276
    Any chance of fitting 17x8.5 ET12, 235/40/17 Falken RT615k? Fenders are pulled front and rear, GC 600/800 coils with shortened housings, just wondering if I will clear the inside of the quarter panel in the rear
    - '88 m54 coupe
    <3
    • v8fc3s
      • Apr 2009
      • 105
      #7277
      Wheels or tires? Ill take you up on that
      • e30eu
        • Mar 2014
        • 15
        #7278
        318is with JOM coilovers. Set of 16x9 ET20 with 225/40 tyres. Would fit or need spacers?
        • gills
          • Jan 2006
          • 275
          #7279
          Ok, sorry if this has been answered already, but will 17x8 et20 Style 32's fit/clear an E30 with 99 E36 M3 full front supsension/brakes and full M roadster/coupe rear suspension brakes? Looking to buy a set local to me and just want to confirm if it's feasible.
          I plan on running GC's setup: http://www.ground-control-store.com/.../II=812/CA=242
          Thanks!
          • Lötjönen
            • Feb 2014
            • 23
            #7280
            318iS on joms. I have 16x8 / 16x9 wheels. What tires i buy for them? Im thinking
            i want mild stretch so im thinking 195/45 - 205/45 or 195/45 - 215/40 setup. I looking for similar sidewall and similar look
            Sorry for my bad english!
            e30 318iS http://www.r3vlimited.com/board/showthread.php?t=315644
            • Mystikal
              Wheel Fitment Expert
              • 9602
              #7281
              Too aggressive IMO.
              • Mystikal
                • 9602
                #7282
                Fronts will not fit with those tires. Also need 8-10mm front spacers to clear the struts. 205/45 tires are ideal.
                • Mystikal
                  • 9602
                  #7283
                  Thanks!
                  The fronts would be flush/poking and the rears will be sunken in slightly. You can balance this out with spacers, but 205/40 tires are your limit.
                  • Mystikal
                    • 9602
                    #7284
                    205/45 225/40 if the offsets are perfect. 195/45 215/40 otherwise.
                    • gills
                      • Jan 2006
                      • 275
                      #7285
                      205 tires are the limit all around or just at the front? I'll be running about -2° to -3° camber on the front. No more than that though.
                      • Lötjönen
                        • Feb 2014
                        • 23
                        #7286
                        ET 5 front and rear
                        • Mystikal
                          • 9602
                          #7287
                          Just the front. For the rears you can fit a 215/40.
                          • Mystikal
                            • 9602
                            #7288
                            ET 5 front and rear
                            Skinnier ones then.
                            • gills
                              • Jan 2006
                              • 275
                              #7289
                              I'm assuming this is without a roll and slight pull? Will be doing both. Regardless, I need more meat for S54 power. I would like to fit at least a 235 in the rear.
                              Can 17x9's with a proper offset( ~+35) work on the front?
                              • e30eu
                                • Mar 2014
                                • 15
                                #7290
                                But would 215/40/16 be good both, rear and front? Or better to use 45 height?
                                I try to get the same wide tyres, otherwise the front look stretch and rear not.
                                Thanks
