Ok, what about 17x9 et30 Apex ARC-8's at all 4 corners?
edit:
1" total wider; 1/2" more per side; 10mm (0.394") more offset toward inside fender; therefore the 9" wide wheel will stick out about 2.7mm more and be about 23mm closer to the strut housing/inside fender than a 17x8 et20....not good..
Is there a problem with inside clearance as well or is there generally plenty of room in there running the 5-lug setup I want to run?
					edit:
