This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #7306
    Originally posted by gills
    First off, thanks for being so helpful. Much appreciated.
    I just want to make sure that you know I'm using a full MZ3/coupe full rear setup, so will they actually be mismatched on the E30? Based on Calvin Zero's 5-lug conversion site, I won't be that mismatched (?) http://clavinzero.com/e30-5-lug/
    Thanks again...
    Mismatched relative to the fronts.
    • Mystikal
      • 9602
      #7307
      Originally posted by CLM21
      I am in the process of an LS swap and want to run at least 275+ on the back, and at least want the option of doing the same on the front. Was looking at ccw wheels. Something like this probably in the 17x11:
      http://www.ccwheel.com/wheels-display.php?view=Classic2PC
      What all is needed to fit a tire size this large on an e30?
      Just want to make sure I'm not missing anything, I'm new to this platform.
      Metal cutting and fender flares. Anything larger than a 245 requires body modding.
      • gills
        • Jan 2006
        • 275
        #7308
        got ya.
        Ok, here's what I'm leaning towards:
        Staggered Apex ARC-8's
        Front: 17x8.5 et40
        Rear: 17x9 et30
        Tires: 225/45 front with 255/40 rear (25" OD for both), or just 235/40 all around (24.4" OD)
        Let me know what you think,
        Tom
        • Mystikal
          • 9602
          #7309
          Originally posted by Brisbane E30
          I have a 1991 E30 318is with an S50B32 conversion.
          I am running KW V2 suspension and the wheel specs are as follows:
          Simmons FR18
          F: 18x8 ET 15
          R: 18x9 ET 25
          Tyres currently are 225/35/18.
          Given the engine swap I am wanting to run stickier rubber (looking at Bridgestone RE-11s) and wider tyres.
          The rear guards are rolled.
          Would 235/35/18 or 245/35/18 fit? And if so what should I run on the front?
          Cheers.
          Nice wheels. Unfortunately you're just about at the limit for tire fitment. The fronts are maxed out at 225/35 and the rears could just take a 235/35. 245/35 will rub.
          • Mystikal
            • 9602
            #7310
            got ya.
            Front: 17x8.5 et40
            Rear: 17x9 et30
            Tom
            Good wheel choice. 235/40 all around is safe, but 245/40 rears are possible if the fitment is just right. I can't say 100% for sure as experience with Z3M setups is a bit scarce. Might be a good idea to test fit the wheels first.
            • Brisbane E30
              • Jan 2013
              • 99
              #7311
              Mate thank you very much for your reply.
              If I can fit 235/35 under the rear (I will see if I can grab a tyre in that size for a test fit) am I better off going something like a 215/40 front?
              Cheers,
              Tim.
              E30 318is S50B32 powered
              • Nuai87
                • Oct 2013
                • 8
                #7312
                16x8 Offset +25 lowered 3 inches on race land coil overs. And now I need tires but I don't know what size I can I while keeping stock fenders
                • Mystikal
                  • 9602
                  #7313
                  Cheers,
                  Tim.
                  No definitely not, 215/40/18 is much too tall. 225/35 is ideal.
                  • Mystikal
                    • 9602
                    #7314
                    3mm front spacers might be necessary depending on where your spring perch lands. Otherwise, 205/45, 205/50, 215/45, and 225/45 all fit.
                    • Brisbane E30
                      • Jan 2013
                      • 99
                      #7315
                      Can I start by thanking you very much for your advice. It is much appreciated.
                      I have one further question - if I'm running a 35 series tyre in the rear shouldn't I be running a 40 series in the front to keep rolling diameter much the same? Or will the difference be negligible?
                      Thank you again.
                      Tim.
                      • AWDBOB
                        • Aug 2013
                        • 4375
                        #7316
                        Hey folks, what is the best offset for a 16x9 wheel to run a 275/45 out back?
                        • Mystikal
                          • 9602
                          #7317
                          Thank you again.
                          Tim.
                          No, 225/35 is closer in diameter to 235/35 than 215/40. Also it really doesn't matter functionally with the E30's ancient ABS and lack of stability control.
                          • Mystikal
                            • 9602
                            #7318
                            I don't know what car this is for, if it has flares, etc.
                            • AWDBOB
                              • Aug 2013
                              • 4375
                              #7319
                              Sorry, man. No flares currently on the 1989 325es. Suspension isn't slammed.
                              • mohamed...
                                • Oct 2012
                                • 577
                                #7320
                                i have 2 sets of wheels.one is a set of 17x8/9 style 32s with an offset of 26/20 and then a set of 17x8 e39 style 5s with an offset of 20. i will have e30 m3 rear 5 lug and then lativian spindle sleeves which widen the front by 12mm on each side. my question is can i run 235/40/17 all around on both sets? i am on ground controls and all the fenders will be roller. thanks!
                                E30 M30 B35 Swap Mounts!
                                http://store.garagistic.com/ocart/e3...=5475809a87e04
