This is a sticky topic.
  • Yonkers320is
    • Jun 2010
    • 15
    #7411
    17x7.5 et20, what tire size recommended? some people told me 215-40/17, others 225-45/17. I have 91 325 on billies and H&R sports...
    • Edirtyy808
      • Apr 2012
      • 297
      #7412
      17x9.5 17x11 et-13 all around. (negative offset) how much will it stick out?
      • Mohit
        • Nov 2013
        • 80
        #7413
        If I wanted to run e38 Style 5s (filled and redrilled), 16x8 et23, what else would I need to make it work? Do I need 10mm spacers? Do I need to pull any fenders? I want to achieve the same look as the April COTM, Neil's e30.
        • JinormusJ
          • 6887
          #7414
          Originally posted by Mystikal
          Neither would fit as the wheel is so far out. You need an undersized tire. 185/55 or 195/50 max.
          Funnily enough, I checked the original et on the wheels, and it's actually 30, not 20.
          That leaves my final et coming out to 12f and 10r with the spacers I'm interested in.
          Would 185/65 now work in this case with a roll?
          • janders211
            • Mar 2014
            • 5
            #7415
            1991 318is, H&R pro or race. Willing to do minor fender rolling. I want the most tire possible.
            Questions:
            1. Can I run Continental race slicks sized 225/40/17 all around (these run wide…near 245 width)? If so-what width/offset 17 (they run square-ish on 8-9” wheels).
            2. I want to run the most street tire on n 16s or 17’s. What sizes/offsets to get most tire with my setup.
            Thanks!
            '95 E34 540i 6 speed dd'd and tracked with mods
            '88 E24 635CSI 5 speed dd'd and tracked with mods
            '91 E30 318is 5 speed...soon to be turboed
            • DatUtahGuy
              • Jan 2007
              • 3146
              #7416
              ASK ALL WHEEL/TIRE FITMENT QUESTIONS HERE - The Official Wheel/Tire Fitment T...
              General knowledge question, what is the size difference between a 205/40/17 and a 215/40/17 in terms of sidewall size. I am pretty low on coilovers and don't want to rub on the back. Anyone with this setup have knowledge?
              YOUTUBE: AR Perez
              If lucky, the E36 will die peacefully, in its natural habitat, and be given the prestigious honor of donating its parts to an E30
              • janders211
                • Mar 2014
                • 5
                #7417
                4mm
                The numbers tell you what the sidewall side is. For example the 40 stands for 40% of the width. So a 205/40 has a sidewall width of 82mm (205mm times 40% (0.40)), and a 215/40 has a sidewall width of 86mm (215mm times 40% (0.40).
                • Mystikal
                  Wheel Fitment Expert
                  • 9602
                  #7418
                  Originally posted by Jonnywachter
                  im looking into a set of 16x9 +6 with a 245/35/16 tire, i want a meaty fitment but will this sit flush with the fender and clear the strut?
                  Won't fit at all, too aggressive on the fender.
                  • Mystikal
                    • 9602
                    #7419
                    Originally posted by nerdydorkus
                    Help! How will this fit:
                    15x7 et 10? Will i need a fender roll?
                    Fits fine with a 205/50.
                    • Mystikal
                      • 9602
                      #7420
                      Originally posted by RedReplicant
                      What does it take to clear 16x8 +20 / 16x9 +15 on a 91? H&R race springs.
                      205/45 all around, rear fender roll
                      • Mystikal
                        • 9602
                        #7421
                        Originally posted by ajD4bmw
                        I'm about to pull the trigger on ESM 002r 16x8 ET20 all around, but i'm uncertain on the tire selection.
                        My car is an 89' coupe on IE stg3 race springs/Bilstein sports. I want to minimize stretch (205/45 on an 8" wide wheel still looks OK to my eyes and doesn't seem unsafe, but it's at the limit IMO). I also need enough sidewall to handle the rough roads in WI. How big of a tire can I fit? What's the typical tire for these wheel/suspension specs with disregard to potholes?
                        Get 205/50s.
                        • Mystikal
                          • 9602
                          #7422
                          215/40. 225/45 does not fit.
                          • Mystikal
                            • 9602
                            #7423
                            About 1.5" past the fender in the front and 2.5" past the rears. Very ugly.
                            • Mystikal
                              • 9602
                              #7424
                              You will need spacers if not now, when you replace your brake pads. If you like the look of that car copy it, 10mm spacers all around and 205/45s is a good combo.
                              • Mystikal
                                • 9602
                                #7425
                                Still a bit too tall for the front if you're lowered. I'd recommend 185/60 or 195/55.
