This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #8911
    Originally posted by Das Delfin
    Hi Jay. Thanks for being here after all these years. I have a question about tire size for a 16x7.5 et20 wheel.
    I see most people run 205/45 but 205/50 has a more similar rolling diameter. Any difference in fit? Car is on H&R sports. Convertible with lower rear arches
    Thanks!
    I try! I wish I could stop by more often but life is seriously in the way.
    205/50 is the correct and more popular size. 205/45 is for stancey fitments.
    • Mystikal
      • 9602
      #8912
      Originally posted by Jimmy85'E30
      I have a 87 325is I have 20mm adapters for my style 5's 17x8 et20 with solid offset control arm bushings. What size tire can I run the front and the rear has 12mm solid riser bushings for the subframe there for less camber. Im also running H&R Race Springs. I have roller fenders.. I plan on drifting and aggressively driving the car so NO RUBBING ALOUD!!!!!!!!! lol
      You definitely bought the wrong wheels then. They don't fit properly at all, and will rub.
      • Mystikal
        • 9602
        #8913
        Originally posted by Best_name_available
        Okay guys, I need to know how much spacer I need. I ordered a set of kamotors ultrawides so I'm not too worried about poke, but here's the question. The wheels I got are a 17x10 square setup with a +15 et. I already run a 5mm spacer up front to clear basketweaves on my coilovers. What size spacer will I need to fit the fronts?
        15mm front spacers.
        • Mystikal
          • 9602
          #8914
          Originally posted by PogiMonster
          I'm looking at possibly running a set of klutch sl1's in a 15x8.5 et17 spec. What tire size would be best? Ideally I'd like to run a thicker sidewall 50/55? Thoughts? My car has the gc coilover spring kit/bilstein sports. Thanks in advance!
          205/50 for sure.
          • Mystikal
            • 9602
            #8915
            Originally posted by Steve Corbett
            4x100 to 5x120 18mm adapters, 89 325I on H&R Sport Springs w/Bilstein Sports. Looking at E38 Style 5's 16x8 wheels. Will they fit with without rolling fenders? Tire size?
            Need to roll fenders and run 205/45s. Will still rub occasionally. Not a great fitment.
            • Mystikal
              • 9602
              #8916
              Originally posted by perVert
              I just bought an 87 325i very and will lower it with h&r sports with Billy sports. Can I put esm 002s 16x8 et20s with Kumho Ecsta AST Ku25 205/50r/16 without rolling fenders or rubbing?
              Should just squeeze by without rubbing. I'd suggest ANY tire but ASTs though, they are seriously awful.
              • Mystikal
                • 9602
                #8917
                Originally posted by gotane30
                looking at buying Klutch SL1 16x8 et15 (front) and 16x9 et20 (rear).
                85 325e on GC coils.
                What size rubber should I run to avoid rubbing/fender rolling/stretch?
                and will I need spacers?
                Not possible without both stretch and rolling. 205/45 front 225/40 rear, rolled rears.
                • Mystikal
                  • 9602
                  #8918
                  Originally posted by alas
                  Ok - looking to see if I can run this set up without needing spacers on my 1989 325i with a small roll in the rear. Currently on Billy/H&R spring combo. This will probably change.
                  15x6.5 et 32 on a 205 tire
                  or
                  15x6.5 et 32 on a 215 tire.
                  I calculated max back space for 15" is 131mm and with tires about 129mm. Seems like if i ran 215's and they were really 215mm, I'd have issues. Can you confirm?
                  Thanks
                  Paper thin strut clearance. 205/50 will work, 205/55 will probably touch the struts.
                  • Mystikal
                    • 9602
                    #8919
                    Originally posted by Tree25
                    Want to know if or what ill need for this setup to fit my 87 325is
                    Front Wheels: 16" x 8"
                    Rear Wheels: 16" x 9"
                    Bolt Pattern: 4x100 /114
                    Front Offset: 20 ET
                    Rear Offset: 15 ET
                    Center Bore: 73.1
                    Sent from my SM-G928V using Tapatalk
                    205/45 front, 215/45 rear, rear roll. Hubcentric rings.
                    • Mystikal
                      • 9602
                      #8920
                      Originally posted by Bones566
                      1987 325es. Koenig feather 16x7. Offset +35 what's the max tire size and will it handle any drop springs if the tire size is reduced from max.
                      Bad offset, won't work without spacers.
                      • Mystikal
                        • 9602
                        #8921
                        Originally posted by digital.aaron
                        90 325is with ksport coils
                        rear: 16x9 et20, currently running 215/40/16 with 5mm spacers.
                        I really want to move up to 225s on the rear, but 225/45s are laughably difficult to find. can I remove my 5mm spacer and run a 225/50 on the 16x9 without rubbing? I have some basic fender rolling done, but the 215/40s with the 5mm spacer rub with enough load.
                        Nope. And you live in America, land of internet purchasing. Nothing is difficult to find!
                        • Mystikal
                          • 9602
                          #8922
                          Originally posted by Nick_e30
                          Looking at 15 x 8.5 wheels, any recommendations on tire size?
                          Sent from my SM-G930V using Tapatalk
                          This is about 20% of the info I need. See the first post.
                          • Tree25
                            • 118
                            #8923
                            Thanks Mystikal! I appreciate your time and knowledge.
                            Do you know where and what size hubcentric rings? Never heard of these before
                            • Mystikal
                              • 9602
                              #8924
                              Np! 73 to 57.1mm, which is one of the most common around. Any local wheel shop should have them.
                              • runnoelrun
                                • Apr 2013
                                • 32
                                #8925
                                First off. Thank you for your input over the years.
                                Canadian people always helping out the homies.
                                Currently running 16x8 +28 offset
                                205/45 with h&r spring front / vogtland rears +20mm spacer (raises the car) because I drive a vert. Heavier in the back.
                                Question: Do you think I could run 235s all around, already have fenders rolled very professionally done. ( I like square set ups)
                                Thank you in advance.
                                Mid life crisis.
