	This is a sticky topic.
 My fenders were rolled to fit 235/40r17 with 17x8 et25. How bad will 225/50r16's be on 16x8.5 et14-19ish and 16x9 et18?
 Edit: what about 215/50r16's?
 Thanks, JayLast edited by lambo; 05-29-2014, 04:57 PM.
 Originally posted by SpasticDwarf;n6449866Honestly I built it just to have a place to sit and listen to Hotline Bling on repeat.Comment
 255/40/17 with flares. They will apparently fit, but:
 1. Will I have to change diff ratio to compensate for the slightly increased rolling diameter, and
 2. Will it be undriveable with no power steering and an E36 rack
 -edit-
 Also, will 235/40/17 fit on unrolled fenders on my 1990 iS? They should be what, like a 30 something offset? Or will I have to rollLast edited by econti; 06-01-2014, 06:48 PM.Comment
 Hi Jay,
 I currently have a stock suspension on an 89 vert and I want to run a staggered set of ESM-003s
 I dont really want to roll fender lips.
 ET: 25mm
 Front: 17x7
 Rear: 17x8.5
 Will I need spacers?
 What Tires can I run?
 Can I even think about a small drop in height or changing tire diameter to fill the wheel wells?
 Thanks
 Bruce89 e30 white vert
 88 e30 Red vert
 2003 330i sedan
 2011 E93 335is
 2007 Z4Si (gone)Comment
 1. No255/40/17 with flares. They will apparently fit, but:
 -edit-
 2. No
 235/40 will only fit without a roll with staggered wheel offsets (17x8 +25 front +30 rear).Comment
 205/40 front, 215/40 rear. Should clear without rolling or spacers.Hi Jay,
 ET: 25mm
 Front: 17x7
 Rear: 17x8.5
 Thanks
 Bruce
 Once you drop it you will likely need a minor rear roll. Very minor.Comment
 Currently running Borbet 15x7 et 25. Would a 15 x7 et 38 work. If so, what tire size would do well. 91 318is, non rolled fenders, Bilsteins and H&R. Thanks in advance.
 Also, would these et 38 rims transfer to a 1976 BMW 2002. Currently running 15 x 7 et 20. Suspension is Ireland Engineering Stage 1.Comment
 No and no. Spacers for both.Currently running Borbet 15x7 et 25. Would a 15 x7 et 38 work. If so, what tire size would do well. 91 318is, non rolled fenders, Bilsteins and H&R. Thanks in advance.
 Jay, tricky question
 I have a set of wheels under my bed.
 vw fitment 5 x 100. minor issue.
 17x10j et32
 17x8.5 et35
 what would it take to fit these on an e30 late model?
 I have a selection of hammers and grinders and I'm not afraid to use them
 what is the best way out?
 P.s.
 tx for the great thread, trying to get through it all
 200 pages to goComment
