This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #7561
    Originally posted by SmokeE30
    I have a set of 16x7.5et55 if my measurements are correct I know with the 205/55/16 tires that were on them the fit with a 5mm spacer in the front I want to ditch the balloon tires and get something wider and lower profile like 215/45 or 205/45 if I have to. There doesn't seem to be much selection tire wise for what I want to do. The car is on stock suspension for now so for now I'm really trying to figure out what tires and spacers I'm gonna wanna run to put the wheels out nice with the fender. Any insight would be great I know my wheels are not ideal offset but I'm planning on 90mm studs to be able to space men where I need to
    Car is a early model
    205/50, 205/45, 215/45, 225/45. Your offset measurement is wrong for sure though.
    • pbmig
      • Feb 2014
      • 16
      #7562
      Originally posted by Mystikal
      25mm front and rear. Would recommend 195/50 tires.
      thanks man! I woudln't need any fender pulling or rolling yeah?
      • Mystikal
        • 9602
        #7563
        Rear roll, yeah
        • BuBzDub
          • Apr 2014
          • 8
          #7564
          So I changed my mind, I'm going 16x9 et15 what sounds better 205/50/16 or 215/50/16
          • lambo
            Captain Scene Points
            • 10953
            #7565
            My fenders were rolled to fit 235/40r17 with 17x8 et25. How bad will 225/50r16's be on 16x8.5 et14-19ish and 16x9 et18?
            Edit: what about 215/50r16's?
            Thanks, Jay
            • Mystikal
              • 9602
              #7566
              3mm front spacers for most suspension setups. 205/45 or 215/40.
              • Mystikal
                • 9602
                #7567
                Thanks, Jay
                Undriveable with the 225s, occasional rubbing with the 215s. Would highly recommend 215/45.
                • econti
                  • May 2014
                  • 1100
                  #7568
                  255/40/17 with flares. They will apparently fit, but:
                  1. Will I have to change diff ratio to compensate for the slightly increased rolling diameter, and
                  2. Will it be undriveable with no power steering and an E36 rack
                  -edit-
                  Also, will 235/40/17 fit on unrolled fenders on my 1990 iS? They should be what, like a 30 something offset? Or will I have to roll
                  • BruceJ
                    • Sep 2012
                    • 62
                    #7569
                    Hi Jay,
                    I currently have a stock suspension on an 89 vert and I want to run a staggered set of ESM-003s
                    I dont really want to roll fender lips.
                    ET: 25mm
                    Front: 17x7
                    Rear: 17x8.5
                    Will I need spacers?
                    What Tires can I run?
                    Can I even think about a small drop in height or changing tire diameter to fill the wheel wells?
                    Thanks
                    Bruce
                    89 e30 white vert
                    88 e30 Red vert
                    2003 330i sedan
                    2011 E93 335is
                    2007 Z4Si (gone)
                    • Mystikal
                      • 9602
                      #7570
                      -edit-
                      1. No
                      2. No
                      235/40 will only fit without a roll with staggered wheel offsets (17x8 +25 front +30 rear).
                      • Mystikal
                        • 9602
                        #7571
                        Originally posted by BruceJ
                        Hi Jay,
                        ET: 25mm
                        Front: 17x7
                        Rear: 17x8.5
                        Thanks
                        Bruce
                        205/40 front, 215/40 rear. Should clear without rolling or spacers.
                        Once you drop it you will likely need a minor rear roll. Very minor.
                        • FL318is
                          • Sep 2006
                          • 1396
                          #7572
                          Currently running Borbet 15x7 et 25. Would a 15 x7 et 38 work. If so, what tire size would do well. 91 318is, non rolled fenders, Bilsteins and H&R. Thanks in advance.
                          Also, would these et 38 rims transfer to a 1976 BMW 2002. Currently running 15 x 7 et 20. Suspension is Ireland Engineering Stage 1.
                          • Mystikal
                            • 9602
                            #7573
                            No and no. Spacers for both.
                            • econti
                              • May 2014
                              • 1100
                              #7574
                              1. No
                              2. No
                              Great, thanks.
                              To run same offset all round with a roll, +30 is what I should run?
                              • bmwmaniac2
                                • Jun 2014
                                • 14
                                #7575
                                Jay, tricky question
                                I have a set of wheels under my bed.
                                vw fitment 5 x 100. minor issue.
                                17x10j et32
                                17x8.5 et35
                                what would it take to fit these on an e30 late model?
                                I have a selection of hammers and grinders and I'm not afraid to use them
                                what is the best way out?
                                P.s.
                                tx for the great thread, trying to get through it all
                                200 pages to go
