This is a sticky topic.
  • LateFan
    • May 2013
    • 4399
    #8311
    Originally posted by Mystikal
    Depends on the offset of the wheels.
    Thanks. They are ET12 15x7 Alpina reps.
    • Mystikal
      Wheel Fitment Expert
      • 9602
      #8312
      Originally posted by digitalcox
      Hi,
      I just picked up a set of 16x8 et25 wheels for my daily driven '88 e30. The setup on my car includes H&R Race springs, camber plates, m3 cab's.
      The general consensus seems that 225/45's will be the way to go (I am also open to other less aggressive tire options) but I wanted to double check if the additional purchase of spacers will be needed.
      I'm also assuming some fender rolling will be needed as well.
      Thanks for any help in advance,
      Justin
      You will need 5mm front spacers to clear the struts. Otherwise good to go. 225/45s fit fine, often without a roll at that offset.
      • Mystikal
        • 9602
        #8313
        You're asking about the fitment of the 15x8s but gave me the offset of the others...
        • LateFan
          • May 2013
          • 4399
          #8314
          I went ahead and bought the 15x7 square set.
          • digitalcox
            • Jun 2008
            • 109
            #8315
            Thanks Jay for the quick response back, I really appreciate it.
            Have a good one,
            Justin
            • mbonanni
              • Sep 2011
              • 6236
              #8316
              18x8J ET20 & 18x9J ET24
              18mm adapter in the front & 20mm adapter in the rear (or 20mm fr an r)
              Pretty low suspension wise
              Early model vert. Salvage title. Fenders and paint don't matter.
              How could someone make this a thing? RollnPull fnders a loooot? Fender flares? Tire sizes?
              • Mystikal
                • 9602
                #8317
                Lots of rolling, might need a slight pull. Front camber plates would help tuck them in a bit. 215/35 all around is best, you could do 225/35 rears but more pulling would be necessary. There is no 40 series tire that fits don't try even if you have a stack of 16 of them.
                Enjoy your Style 5s / M Parallels / Style 32s. ;)
                • mbonanni
                  • Sep 2011
                  • 6236
                  #8318
                  Camber plates will be installed. And sshhhh don't give it away ;)
                  Sent from my SM-N900P using Tapatalk
                  • noid
                    • 1529
                    #8319
                    Completely stock ride height, what is the widest 16" tire and offset (or range) that can be run without spacers, zero fender roll and absolutely no rubbing anywhere?
                    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
                    Your resource to tools and tips: www.rtstools.com
                    • manicho
                      • 63
                      #8320
                      Hello Jay,
                      Do you know if these http://newhaven.craigslist.org/pts/5058565517.html would fit an 87 with lowering springs.
                      Thank you.
                      • Mystikal
                        • 9602
                        #8321
                        16x7.5, +20 to +28, 225/45.
                        • Mystikal
                          • 9602
                          #8322
                          Originally posted by manicho
                          Hello Jay,
                          Thank you.
                          Hey, those would require spacers to fit an E30. 15mm/20mm would be nice.
                          • noid
                            • 1529
                            #8323
                            You're the man.
                            • 89DelphinE30
                              • 287
                              #8324
                              Can anyone confirm if this offset would fit a 325is E30? I'm looking into purchasing a set of BBS RS wheels tomorrow. I'm not a wheel guy so any help would be great thanks!
                              Thanks
                              16x8 ET20/16x9 ET24
                              • Mystikal
                                • 9602
                                #8325
                                Thanks
                                16x8 ET20/16x9 ET24
                                Whoever built those created about the perfect set of 16" RS' for an E30. Just...perfect.
