This is a sticky topic.
  • Mohit
    • Nov 2013
    • 80
    #7576
    Just wanted to make sure before I placed an order on some Yokohama S. Drives in 205/45/r16
    Would they be a good choice for filled and redrilled e38 style 5s 16x8 et23 with 8mm spacers all around, without rolling any fenders?
    • Mystikal
      Wheel Fitment Expert
      • 9602
      #7577
      Originally posted by econti
      Great, thanks.
      To run same offset all round with a roll, +30 is what I should run?
      +25 all around
      • Mystikal
        • 9602
        #7578
        Originally posted by bmwmaniac2
        Jay, tricky question
        I have a set of wheels under my bed.
        vw fitment 5 x 100. minor issue.
        17x10j et32
        17x8.5 et35
        what would it take to fit these on an e30 late model?
        I have a selection of hammers and grinders and I'm not afraid to use them
        what is the best way out?
        P.s.
        tx for the great thread, trying to get through it all
        200 pages to go
        Those are just barely workable, but it's extreme. Get 18mm adapters, 205/40 and 215/40 (or 225/35) tires, stiff coilovers, and a fender roller.
        • Mystikal
          • 9602
          #7579
          Yup.
          • econti
            • May 2014
            • 1095
            #7580
            Originally posted by Mystikal
            +25 all around
            Great, thanks man.
            It's nice to have someone with definitive answers haha.
            • ian e30 318is
              • Mar 2007
              • 1806
              #7581
              Will a 225/50r16 RS3 or ZII work on a 16x8 et 20 with rolled fenders? The fenders are not pulled and I'm on coils and will pull the plastic liners. I'm a little worried about the strut rubbing more than the fenders. There are so many good deals on tire rack for this size. Thanks.
              1991 LS1 Swapped 318is
              Instagram:
              https://instagram.com/saltybeast/
              LS Build Thread:
              https://www.r3vlimited.com/board/for...s-e30-ls1-swap
              • Mystikal
                • 9602
                #7582
                Originally posted by Nick's e30
                16x8 +20 front
                16x9 +15 rear
                What sort of spacer do I need to run a flush or close to flush setup? What size tire should accompany each wheel if I am going for a setup that will be as flush as possible?
                I've run 205-40-16 on a 16x9 square setup with a 5mm spacer on the front but I'd like more tire this time and less poke up front (from what I remember the front poked a bit and the rear was a bit inset).
                I'd really love to run a 215-45-16 out back if I can get away with it, but I feel like any kind of spacer becomes out of the question at that point, and spacing the wheel becomes more realistic an idea with a 205-45-16.
                Anyway, help please and thanks!
                You're spot-on with everything you've come up with. I think the best setup will be a 195/45 205/45 tire stagger with a 10-12mm front spacer and 5mm rear (you kept the old ones? ha).
                www.onlinetires.com for weird 16" tires like these. No they're not sponsoring me, just a great site for oddball tires.
                • Mystikal
                  • 9602
                  #7583
                  It'll clear the strut, but will rub the fenders and inner well with the steering locked. Some guys have put up with it on those exact wheels before, but I try not to recommend something that doesn't 100% clear, at least theoretically.
                  • 928*dog
                    • Jun 2014
                    • 4
                    #7584
                    Hi i'm about to buy a set of 17" 17x7 mod tech wheels with 205/40/17 tires on them, will these fit with little or no modification to the wheel wells? i drive a 91 318i with stock suspension
                    • Mohit
                      • Nov 2013
                      • 80
                      #7585
                      Yup.
                      I found a set of Kumho Ecsta AST in 205/45r16 for sale for cheap, would they be an okay alternative? Or should I stick with the Yokohamas?
                      • Mystikal
                        • 9602
                        #7586
                        Need to know the offset of the wheels.
                        • Mystikal
                          • 9602
                          #7587
                          They're honestly a really bad tire, borderline dangerous in the wet. Noisy too. I'd skip them if possible. Try looking into Federal tires, cheap and great in that size.
                          • ninekrpm
                            • Oct 2013
                            • 43
                            #7588
                            Looking to run a wider tyre in the back - currently running 205/45/17 squared...
                            anyone running 17x8 on 205/45/17 front and 225/45/17 (this will cause .5" larger diameter in the back; but size options are limited).
                            • JinormusJ
                              • 6887
                              #7589
                              ASK ALL WHEEL/TIRE FITMENT QUESTIONS HERE - The Official Wheel/Tire Fitment T...
                              Front: 16x7.5 et13 - 185/55/16
                              Rear: 16x8.5 et25 - 215/50/16 (prefer oversized if possible in the rear)
                              Non-M e30 running e30 m3 fully adjustable GC coils. 450f/650r. All corners rolled flat
                              • 928*dog
                                • Jun 2014
                                • 4
                                #7590
                                My bad, the offset is +40 and they have Lexani Tires on them, does anyone have exp with this brand? Thanks in advance!
