Thank you
	This is a sticky topic.
 Streetable poly mounts, trans mounts are here!
 http://www.r3vlimited.com/board/show...ght=streetable
 '94 318i
 '07 335i
 '11 X5
 '89 325ic m30b35
 16x8 +0... what do I need to not require insane fender hackage? Is +0 too low?91 318is - Gone
 16 VW GTI
 07 Aprilia TuonoComment
 Looking at running a set of Rota Slip Streams, 16x8 ET40. I am guessing a small spacer will be required? 1989 325I 4x100 on HR Sport springs with Bilstien Sports.Last edited by Steve Corbett; 07-24-2014, 01:57 PM.sigpic
 Steve Corbett
 1983 528E Scrapped
 1983 528E Sold
 1984 745I
 1984 325E - Sold
 1989 325I Bronzit-Sold
 1989 325I Zinno
 1988 635CSIComment
 I'm thinking about some 16x8s with +20 offset on my 86 ES:
 Do 225/45/16s need rolling for lowered fender clearance or covering poke or both?
 Can 245/45/16s clear everything if I get adventurous?
 Also thinking about 15x8 +15 wheels, would 225/45/15s work in that case?Comment
 225/45s will work with no roll on an early car as long as it's not too low. For slamming, it'll need to be rolled.I'm thinking about some 16x8s with +20 offset on my 86 ES:
 245/45 will work if it's not low, has a high spring rate (600lb+) and with a fender roll. Rear only.
 15" setup will work fine, yup.Comment
 Steve Corbett
 1983 528E Scrapped
 1983 528E Sold
 1984 745I
 1984 325E - Sold
 1989 325I Zinno
 1988 635CSIComment
 Quick question, I am looking for a similiar stretch, going from 16x9 (215/40/16) to a 16x8. I am leaning towards a 205/45/16 to achieve a similiar look, but reading the specs on tire rack, the overall diameter appears that I will increase the overall diameter by a little bit. Not a terrible thing imo, the 215/40/16 felt a little short anyways. Does the 205 45 seem like a good move?Supatek -noun - your basic know it allComment
 Thanks! Update: Used 10mm hubcentric spacers, which required slightly re-contouring the bevel at the edge of the hubcentric part of the hub to kill a wobble condition. Anyway, now there's ~5mm clearance between the tire sidewall and the strut. I don't think a 5mm spacer would have done it. Fender clearance not a problem, but I have HR/OE sport springs which are taller than what most guys are running.Comment
 simple question, i aquired a set of bbs RC 090 8j x 17 h2 IS20 i have a 1984 325e does anyone have any pix of these on the e30? what tire size recomendations? i plan on 5 lug conversion (of course) and a lot of other mods down the road. just need feedback and weigh my options thanks guys/galsComment
 ASK ALL WHEEL/TIRE FITMENT QUESTIONS HERE - The Official Wheel/Tire Fitment T...
 17x9 et38 square, will need to run adapters. Late model on Fortune Auto coilovers.
 What am I looking at to get a semi flush look with these?sigpicComment
 Hi Jay,
 What size of spacer and tires would you recommend:
 16x7.5 et35
 1989 vert with M3 springs
 I am currently running 15x7.5 et 25 and would like to maintain the same look but with a 16x7.5 rims. Thank you!
