This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #8011
    Originally posted by Mushroom Stew
    Here's some specs of a wheel I'm looking at. I run Billy sport shocks and H&R Sport springs.
    ROTA WHEELS - GRID_V
    15X7"
    Bolt Pattern 4X100mm
    Offset 20 mm
    Lip Size: 2.2.5"
    Hub Bore Size: 67.1 mm
    OR
    Some used Volk wheels I just found nearby
    16x7
    Offset 42
    Hubbore 73mm
    I'm a total newb, so whatever I'd need/to do to make these fit would be much appreciated
    The Rotas bolt right up, just need hubcentric rings (67mm - 57.1mm). Use 205/50, 205/55, or 225/45 tires.
    The Volks require 20mm spacers all around as well as hubcentric rings. 205/50, 205/45, or 225/45 tires all fit.
    • Jb325is
      • 2137
      #8012
      Originally posted by Mystikal
      I can't see a 17x9 +40 fitting without spacers. A 17x10 +20 (wheel only, no tires) clears the trailing arms by a few hairs, and the 17x9s would be 7mm closer. Hence why I suggest 10mm spacers.
      I think you're spot on, I have 17x9ET22 with a 245 currently and it barely rubs the inside of the rear quarter (late model) under compression. Maybe 15mm spacer with 235's, that tire size seems to be getting phased out though, you can get everything in 245 but it's much taller
      - '88 m54 coupe
      <3
      • dishwab
        • Mar 2012
        • 681
        #8013
        Very tight fit. With 205/50s it would be fine, but I think it might rub just a bit with your existing tires.
        Thanks as always! Your help is much appreciated
        • Mushroom Stew
          • Dec 2014
          • 121
          #8014
          Thanks Jay.
          Before I go out and drop any cash, just would like to know whether the Volk's (16x7, Offset: 42) with the tires you mention would require fender rolling (I run billy shocks & HR springs both sport)?
          Also, if anyone has pictures of a similar style set up, I would love to see!
          • AusScare
            • Jun 2014
            • 220
            #8015
            Thanks for the info. I might go ahead with 17x8 +20 all round then, with 215/40 front and 235/40 rear. That should fit without issue I understand.
            '90 318is
            • Mystikal
              • 9602
              #8016
              Thanks Jay.
              100% won't rub with the 205 choices, won't rub 99% of the time with the 225/45s and no rolling.
              • Mystikal
                • 9602
                #8017
                That will most definitely rub in the back. +25 is the key rear offset for 17x8 235/40.
                • E30dxb
                  • Jan 2015
                  • 46
                  #8018
                  BBS rs
                  Hi Mystikal
                  Please I need your advice , I have a set of bbs rs 003 ...holy grail ;) 7jx16 et 25 rebuilt to 8.5 front (2.5 inch lip) and 9 rear (3inch lip) ...dunno the final ET !
                  Car is lowered on GC full system , the front strut is shortened 1.5 inch .
                  What is the perfect tires size with mild stretch and no rubbing ? ( fender not rolled)
                  Your advice is appreciated .
                  • elcoy
                    • Jan 2011
                    • 569
                    #8019
                    Are 17x9.5 (+19 so spacers) all around on a 318is with H&R Springs and Billys a bad idea with any tire?
                    The Lineup in order of appearance:
                    91 535i
                    91 318is 5 Lug/E46M3 Brakes
                    91 325is w/ S52
                    88 Vert Plastic Bumper Swap
                    88 M3 ;D
                    91 325ix 5 speed
                    89 Vert Royalblau Metallic
                    73 2002
                    1986 325es --> is swap Rallycross Car!!
                    1995 Chevy G30 Tow Rig... *I SOLD A CAR!!*
                    1993 525i Granitsilber Metallic Touring
                    Need a 91 M5 bad but wife would shoot me...twice
                    *UPDATE: got a 93 M5 and still alive
                    1972 Jeep Wagoneer
                    1975 2002 five speed
                    Check out:
                    Elhartspeedshop.com
                    • Neil1138
                      • 527
                      #8020
                      Not a fitment question, but a grip question. Currently running 205/45/16 s.drives on my s52 swap. Going to step down to 15's plus meat flush for sake of dd'ability. Unfortunately it seems my only options are either 205/55/15 or 225/50/15, the latter of which only comes in kumho ecsta ast's. The 205/55/15 options are alright but I know grip wise, it's going to be the same as what I already have. I'm not willing to go undersized at all.
                      So the question is... grip wise... 205/45/16 s.drives vs 225/50/15 kumho ecsta ast. I'm pretty sure I know the answer to this (kumho ast's suck), I'm just always down for a surprise. These would go on a 15x7.5" btw. Thank you for any advice.
                      • whitebulat22
                        • Apr 2014
                        • 330
                        #8021
                        Now that Toyo added a tire to the short list of available 245 / 45 / 16s for the road I'm stoked on getting a set of 16x9s and getting a set of those tires for road and track. I'm running IE3 springs with all of the spring pads and no drop hats or anything + Konis. I plan to add camber plates and fender flares. Can I keep the offset of the wheels close to +20 ish and how much would I need to attack the front fenders for vertical clearance?
                        Thanks!
                        • Mystikal
                          • 9602
                          #8022
                          Originally posted by E30dxb
                          Hi Mystikal
                          16x8.5 +6
                          16x9 +0
                          I've seen these run before, but it is an extreme fitment. You will need rolled and maybe slightly pulled fenders, especially the rears. 205/45 all around.
                          • Mystikal
                            • 9602
                            #8023
                            You will need 12-15mm front spacers and stretched tires. At H&R ride height I think it would look really bad. Only way to pull something like those off is with mega tire stretch and the car slammed to the pavement.
                            • Mystikal
                              • 9602
                              #8024
                              S.drives by a mile. 225/45/15 would be your best option, despite the undersized diameter.
                              • Mystikal
                                • 9602
                                #8025
                                Thanks!
                                +10 is necessary to clear the front struts. Anything +25 or numerically lower will work in the rear. Unsure of how much bodywork will be needed exactly but it's not an outlandish setup. With flares you'll be more than okay.
