What do you suggest for the H&R ride height? 17x8 +40 front and 17x9 +42 rear with some spacers? I currently have 17x7 and wanted to go wider...
This is a sticky topic.
The Lineup in order of appearance:
91 535i
91 318is 5 Lug/E46M3 Brakes
91 325is w/ S52
88 Vert Plastic Bumper Swap
88 M3 ;D
91 325ix 5 speed
89 Vert Royalblau Metallic
73 2002
1986 325es --> is swap Rallycross Car!!
1995 Chevy G30 Tow Rig... *I SOLD A CAR!!*
1993 525i Granitsilber Metallic Touring
Need a 91 M5 bad but wife would shoot me...twice
*UPDATE: got a 93 M5 and still alive
1972 Jeep Wagoneer
1975 2002 five speed
Check out:
Elhartspeedshop.com
sigpic -
Thank you for responding so promptly. Can't express how much I appreciate your help. I know there are more options in that size, but I'm trying to gain a bit of ride height. Mainly due to my sucky ground clearance with the s52 3" exhaust. My current 205/45 s.drives are 590mm, vs 583mm for the 225/45's. Basically the plan is to adjust the coils up while making sure the wheel wells still look filled :rofl:Comment
Thanks! Once again you the man!The Lineup in order of appearance:
91 535i
91 325is w/ S52
88 M3 ;D
91 325ix 5 speed
73 2002
1972 Jeep Wagoneer
Check out:
Elhartspeedshop.com
sigpicComment
I have a machined 5 lug conversion, pushes front out 12mm each side. rear is e30 m3 5 lug width, same as stock. I have a set of style 42 17x8 et 20 all around, im thinking about strapping them with 225/45/17 or should I go 40 aspect ratio? Thanks in advance for the help!
P.S. currently on eibach springs and bilstein sports, soon to be on full ground control coil overs, I have no problem rolling fenders if need be, fronts are already rolled a bit from P.O.
apexgoblin - versteht nicht jeder. Ist auch besser so!
Background:
I'm currently running 16x8 et8 front/16x9 et15 rear with 225/45/16 Falken FK452's all around. I'm happy, but I wish I went 16x9 square.
Tires are almost shot, and the only thing I can find without shipping internationally are two Toyo Proxes T1R 225/45/16 (and they're on clearance for $75/pc). I can ship two 245/45/16 of these for another $400, and I feel it is worth it.
My questions:
1: With 16x9 et15, how hard is it going to be to fit 245/45 in the rear? It is already rolled and pulled somewhat, but it looks pretty close as is.
2: I plan to swap the fronts out for 16x9 et15 as well, which will push my wheel out 6mm more. I've test fitted my current rears to the front and with a 225 it looks like it will work, but would you call me crazy if I try to fit 245's up front after I run out of 225's?Originally posted by priapismMy girl don't know shit, but she bakes a mean cupcake.Originally posted by shamesonUsually it's best not to know how much money you have into your e30Comment
Looking for the best tire fitment for 16x9.5 et 30 front and rear.
15mm spacers would also be needed?Comment
Late Model e30 with rolled fenders on ground control coils, lowered but not dumped.
- car is a turbo car (s52 turbo making 500+whp) so looking to fit largest rear tire I can on the apex acr8 17x8+25 wheels.
Can I fit a 245/40 out back on that wheel? or should I stick to a 235/40 square setup?
- street tires also no Hoosiers. Most likely NT01/Toyo R1R/R888
Thanks!1989 325is - S52 Turbo Swap
1995 M3 - SCCA CStock AutoX Car
1991 318is - M20 swap - 5spd(SOLD)Comment
Test fitted today. These are a lot wider than I anticipated and I'm having some trouble clearing the coilovers. Simply to get an idea, the pictures below show the test fit with 40mm's worth of spacers and camber plates maxed out.
Wheel specs are 16x9.5 CCW LM16's. They were purchased from a local guy here who said they were a +22 offset. But I'm a little confused because with the 40mm spacers, that would put me at -18. Not realistic, right?
Any other ideas on clearing the coilovers?
Download the WheelCo App! https://itunes.apple.com/us/app/whee...046704912?mt=8
Build Thread: http://www.r3vlimited.com/board/showthread.php?t=344312Comment
with a 9.5j wide wheel, you need a final offset to be +6mm to clear the strut housing. The previous owner was wrong with offsets.2014 Alpine White 335i MSport
(Daily Driver)
Full Mperformance Aero
KW V2 Coilovers
VRSF Catless DownpipesComment
