This is a sticky topic.
If I have 16x8 et25. Would 12.5 spacers be over kill for the front? My current tire size is 195-60-15. This will be a temp setup, as I already have these tires and they still have life left. When it is time to change tires. What should I go with, that will give me as much meat as possible? Also, I lowered with H&R cup it.Holy shit did you even read this post before you posted?
http://www.r3vlimited.com/board/announcement.php?f=156
This thread sure sucked last night. It just plain sucked. I've seen threads suck before but this is the suckiest bunch of sucks that ever sucked.Comment
Hi. I've tried searching this and can't seem to find anything. I have an 01 330ci OEM sports suspension. I want to install 17x9 +20mm offset with the OEM size tires. I don't want it stanced too hard, fenders not rolled. I'm not against rolling them either. No plans to lower the car.Comment
If I have 16x8 et25. Would 12.5 spacers be over kill for the front? My current tire size is 195-60-15. This will be a temp setup, as I already have these tires and they still have life left. When it is time to change tires. What should I go with, that will give me as much meat as possible? Also, I lowered with H&R cup it.Comment
Plan on getting these new wheels and I really want to go 16x9"s all around because I've heard from a lot of people that a staggered setup with e30's promotes understeer. I really just want to know if 9" wide tires will fit in the front without rubbing or if I have to run spacers. If I have to I'll run 8"s in the front.
Thanks guys.Comment
205/45R16 is what will work in the front after 10-15mm of spacer and the rears can fit a tire up to 215/50R16 no spacers needed. Correct? My idea is to run 205/45 up front with a 12mm spacer and 205/50 in the rear with a 15mm spacer. will the tires be too odd looking? will everything fit?
Thanks again! super awesome having a resource like this/you. :up:Comment
http://www.klutchwheels.com/wheels/sl1-bronze-w-black-
Thanks guys.Comment
Well then. I guess there was a typo. Lol. I've got 12.5mm spacers on the way for the fronts. In your opinion, whats the most meat I run for a tire sizeHoly shit did you even read this post before you posted?
Alright, so to re-cap..
No, that will rub in the back. What I said earlier was in regards to the rear mostly. +9 is way too low of an offset for a 8.5"/205/50.Comment
