This is a sticky topic.
  • mikebloco
    • Feb 2015
    • 190
    #8221
    Bronzit707: In 205/45 Dunlop direzza z1's, for 215/45 get BFGoodrich gforce rivals
    Mystikal I had to go with et20's all around so I guess I'll see how they fitt when they get here tomorrow.
    • tntomek
      • Jul 2014
      • 15
      #8222
      Bought a set of staggered CR7s.
      16x9 ET25 & 16x7.5 ET30 sitting on 215 40 16 all around (yes front this wide is a bit odd and rear/front rubber isnt matching so open to replacing front tires with something closer to 195)
      Car: 91 318is coupe stock height but will be dropping to a H&R sport (possibly race), not slamming.
      Was told I don't need spacer on rear but 5-8mm in front. Is this enough, a 215 will stick out beyond the 7.5 rim will it not?
      Can anyone please confirm? Thanks!
      FS thread: http://www.r3vlimited.com/board/showthread.php?t=352803
      • Mystikal
        Wheel Fitment Expert
        • 9602
        #8223
        Those are a good offset for the rear 16x9s on a car that won't be slammed. The tire sizes, however, are not. I would go with 205/45 front and either 215/45 or 225/40 rears. 15mm front spacers would be perfect to even out the fitment and for clearance reasons.
        • Terroth
          • Jul 2014
          • 22
          #8224
          15x7 ET+15 Currently running 195/50 due to previous owner
          Wanting to know the widest tyre I can run? Currently set up on King Springs / Koni shocks - Rolled fenders.
          • Slamit34
            • Sep 2012
            • 38
            #8225
            Plan on running 16x9.5 wheels with a +32 offset. what size adapters should i run for the fronts and rears?
            • Mystikal
              • 9602
              #8226
              Originally posted by terroth
              15x7 et+15 currently running 195/50 due to previous owner
              wanting to know the widest tyre i can run? Currently set up on king springs / koni shocks - rolled fenders.
              205/50
              • Mystikal
                • 9602
                #8227
                30mm is safe. 25mm might just barely clear.
                • Slamit34
                  • Sep 2012
                  • 38
                  #8228
                  is that all around or just the fronts?
                  • Mystikal
                    • 9602
                    #8229
                    That's the spacing required for the wheels to clear the front struts. I'd recommend sticking with that offset in the rear also just for looks purposes. The fender work will be substantial though.
                    • ikorgel
                      • Jan 2015
                      • 4
                      #8230
                      Subbed. Will have questions later!
                      • Bejoe16
                        • Jan 2014
                        • 91
                        #8231
                        Wanting to know if I will need any fender work with a 15x8 et20 with 225/50s? It's a stock suspension late model with coilovers in the future.
                        • bwana
                          • Apr 2015
                          • 52
                          #8232
                          Friend of mine got some nice e39 wheels for a good price, they are 15x7 with an offset of 20. the prob is the smallest decent wheel adapter is 18mm thick. Would the poke just be crazy? Or is there a chance it will fit in the fender...
                          He has a 1991 318i, looking at prob getting 205/50-15's on it
                          I park with my feet... sometimes
                          • Mystikal
                            • 9602
                            #8233
                            Yes, flat rear roll is necessary and it might still rub occasionally. Big bubbly tires.
                            • Mystikal
                              • 9602
                              #8234
                              With 195/50s it'd fit. I wouldn't bother personally. Once you spend $400+ on adapters you may as well buy something that actually fits properly.
                              • wildstoats
                                • Sep 2007
                                • 896
                                #8235
                                I'm looking for some input on a new setup. Late model car lowered on GC suspension with a moderate roll all around. Looking to run 16x8 et23 with a 205/50. Seems like 15mm would be a good aggressive fit for the front (thoughts on that?) but what would be the ideal spacer for the rear?
                                Thanks again!
