This is a sticky topic.
  • Malcolm206
    • Jul 2015
    • 84
    #8371
    Trying to choose between a couple new wheels, and I just wanted to make sure none would have any fitment issues. Spacers are fine, but would prefer not to roll the fenders.
    15x7 et 35
    15x8 et25
    16x7.5 et 35
    Running Bilstein Sport struts and springs on a 1988 325i cabrio. Also, if you have recommendations on tires sizes for either that would be greatly appreciated!
    Thanks,
    Malcolm
    1988 E30 325iC
    • nomsg
      • 51
      #8372
      Hey Jay, would 195/60/15 look stretched on euroweaves? I'd like to get 205/55/15 but no one has them in Toronto. I am moderately dropped on H&R Sport springs. TIA.
      • CRBR30
        • Apr 2015
        • 234
        #8373
        Anyone running 205/45/16 front and 205/50 rear? Pics?
        '89 325i RoyalBlau Metallic - Kylie
        Follow me on IG! @its.christiannn
        • Vivek
          attention whore/retard/bitch
          • 6167
          #8374
          I'm mounting some style 32's on my e34, current tires are 215/45 up front and 215/50 in the rear. What do you think of these sizes and what would you suggest if they're less than ideal? I may leave the front alone and put something wider in the rear. I'm okay with (looking for) something slightly taller than stock as long as it doesn't rub with vogtland springs.
          Thanks!
          1992 Mauritiusblau Vert
          2011 Alpinweiss 335is coupe
          2002 540i/6 Black/Black
          2003 GSX-R 750 (RIP)
          • Vivek
            • 6167
            #8375
            Thanks!
            • Mystikal
              Wheel Fitment Expert
              • 9602
              #8376
              Originally posted by hexe30
              16x7.5+20 front
              16x9+15 rear
              Like the tires to be square as possible.
              The wheels you bought do not work with proper fitting tires. You either need new wheels or deal with a lot of stretch. 205/45 all around is best.
              • Mystikal
                • 9602
                #8377
                15x7 et 35
                15x8 et25
                16x7.5 et 35
                Thanks,
                Malcolm
                15x7 et 35 - 15mm spacers and 205/55 tires
                15x8 et25 - 5mm front spacers and 205/55 tires
                16x7.5 et 35 - 15mm spacers and 205/50 tires
                No rubbing on any of those setups.
                • Mystikal
                  • 9602
                  #8378
                  Totally normal, but they might scrub the front fender liners while turning. 195/55 might be a better choice if available.
                  Side note, I can get you 205/55 Nankang NS-20 and Yokohama S.drive on a one-to-two day notice here in the city. Contact me at the shop (www.stancefactory.com) if I can help.
                  • Mystikal
                    • 9602
                    #8379
                    Thanks!
                    Anything up to 245s should fit without any rubbing. 235/45 is ideal, 225/45 is super common and works fine too.
                    • hexe30
                      • Jun 2015
                      • 141
                      #8380
                      I have to believe I can get a larger tire in width on the rear and not 205/45's all around on a staggered set up (which would look like trash, IMO) But thanks anyways. We'll tincker with it and keep you updated.
                      • Malcolm206
                        • Jul 2015
                        • 84
                        #8381
                        Thanks so much. And if I had a 15x7.5 et 32 with 205/55 tires would either 12mm or 15mm spacers work?
                        1988 E30 325iC
                        • Vivek
                          • 6167
                          #8382
                          It all depends on how much rubbing you're willing to deal with...he gave you a size that won't rub. You could put 195's up front and make it staggered
                          • hexe30
                            • Jun 2015
                            • 141
                            #8383
                            What would be required to run a 225/45r16 (9" rim 15et) on the rears? I'm not opposed to pulling or flares on the fenders. They are currently rolled. As well as Im on CAtuned coilovers so I can adjust the height.
                            • Mystikal
                              • 9602
                              #8384
                              lol.
                              Yes, you will need flares to clear a 225/45 without rubbing. Or, just buy wheels that are made for functional E30 fitment. You bought stancey wheels and you're trying to force them to work functionally, essentially a square peg in a round hole. It would seem obvious that wheels better suited to your needs would be a smarter choice than hacking away at quarter panels just to fit a tire size that can work with zero mods on a proper wheel.
                              • Mystikal
                                • 9602
                                #8385
                                Np! Yes, 12 or 15mm will work fine.
