This is a sticky topic.
  • osubeaver
    • Jan 2010
    • 35
    #8416
    H&R Race and Bilstein Sport late arches
    15x7 et30 with 225/45 RS-3
    Intended use is HPDE so just want to clear struts and not rub on arches. I was thinking 10mm spacers but could i get away with 8mm?
    • tonywonder
      • Sep 2009
      • 1688
      #8417
      Late model coupe with e30 m3 5lug, coilovers, and front camber plates.
      What is the largest tire I can fit on 16x8 style 5s with and without fender roll?
      • Mystikal
        Wheel Fitment Expert
        • 9602
        #8418
        Originally posted by apiazza2010
        Z4 hubs is the same as e30 m3 just 5 mm less out. Pretty nice because they are cheap. Front is e36 hubs with adapter nut sleeve
        Sent from my SM-N910T using Tapatalk
        Interesting. I only have E30 M3 hubs as 5-7mm per side wider than E30 4-lug, so does that mean the Z4 hubs are essentially same as stock? Or is the 5mm figure for total rear track?
        Need to nail down those details to be certain, but I can already see your offsets are too low for the tire sizes you want. Mid-30s offsets are likely ideal.
        • Mystikal
          • 9602
          #8419
          Originally posted by Malcolm206
          I decided to go with Konig Tweakd 15x8 et22. Do I need some small spacers to get closer to et20, or should et22 be fine? Also would you recommend 205/50 or 205/55 tires? Lowered on Bilstein Sports all the way around, '88 cabrio.
          Those should be perfect. Either tire size works fine.
          • Mystikal
            • 9602
            #8420
            Originally posted by Js2010
            Thank you.
            Will I need spacers on the front because I am fitting 9js? If I was to fit 7.5j on the front would I still need spacers? Is it normal to fit 9js all round?
            Thanks again great help. JS
            Sent from my Nexus 4 using Tapatalk
            Because of the offset of the 9s. Wheel width means little without offset. Don't concern yourself with the 9s and spacers. 16x9s all around is probably the most commonly asked setup in this thread.
            • Mystikal
              • 9602
              #8421
              Yep. And front only, you can run the rear sans spacers.
              • Mystikal
                • 9602
                #8422
                205/45 without, 215/45 with. Remember not to compare your fitment to guys running a re-drill, your hubs push the wheels out further than 4-luggers.
                • Malcolm206
                  • Jul 2015
                  • 84
                  #8423
                  Thank you!
                  1988 E30 325iC
                  • Shftr8
                    • Aug 2014
                    • 530
                    #8424
                    Ok cant seem to find the exact answer Im looking for so let me ask you. E36 M3 front and Ti rears. Im looking at running some Style 5s I pulled from a E38. I believe they are RC035/38? 17X8 and 17X9 with ET20 and Et25. These should fit with no problem right? and what tires would work best with a slightly lowered car?
                    • Grackle
                      • Jul 2015
                      • 119
                      #8425
                      Looking at some 16x8's et+15mm for my 86es (not lowered yet), 5.5" backspacing.
                      ETA: Also looking at some 17x8, +25mm, 5.48 backspacing. Wanting to avoid spacers and fender rolling if at all possible once I lower the car (probably no more the 1.5"-2" front and rear), trying to get a feel what should fit on the car.
                      Thanks
                      • Mystikal
                        • 9602
                        #8426
                        Fronts will be poking a bit more than the rears, but it's doable. 205/40 and 215/40. Larger tires won't work due to the low offsets.
                        • Mystikal
                          • 9602
                          #8427
                          Thanks
                          Both are great offsets out the box, no spacers needed. 205/45 for the first setup, 215/40 for the second.
                          • Grackle
                            • Jul 2015
                            • 119
                            #8428
                            Awesome, thanks Mystikal!
                            • Js2010
                              • Jul 2015
                              • 6
                              #8429
                              3-5mm front.
                              No.
                              If they did before.
                              If there were before.
                              If the wheels require them.
                              Thanks again.
                              If I use 5mm spacers on the front, will I need longer wheel bolts or will the standard one be OK?
                              • Grackle
                                • Jul 2015
                                • 119
                                #8430
                                Hate to ask again, but 16x8's with a +15mm but a 5.09 backspace. Still good to go?
