This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #8431
    Originally posted by Js2010
    Thanks again.
    If I use 5mm spacers on the front, will I need longer wheel bolts or will the standard one be OK?
    Sent from my Nexus 4 using Tapatalk
    Depends on the thickness of the hub of the wheels you're using, which is a figure no specs will give you unfortunately. But with maybe 80% of wheels, yes, for 5mm spacers you will need longer bolts to retain proper threading.
    • Mystikal
      • 9602
      #8432
      Originally posted by Grackle
      Hate to ask again, but 16x8's with a +15mm but a 5.09 backspace. Still good to go?
      Offset and backspacing are directly related, and redundant to quote both. But you need to confirm what you're getting with the vendors. 8" +15 is 5.09" backspacing, not 5.5".
      • Js2010
        • Jul 2015
        • 6
        #8433
        Thanks I am thinking about putting borbet A on the car. So do you still think I will need longer bolts? Is there a risk the bolts I buy might be too long?
        • Mystikal
          • 9602
          #8434
          I've mounted 16x9 Type A's on an E30 before, but it had custom BC coilovers and therefore didn't need any spacers. Sorry.
          There is a chance of the bolts being too long, yes. Stock shank length is around 24mm. Buy bolts with a 28-32mm shank length and you will be good to go.
          • Grackle
            • Jul 2015
            • 119
            #8435
            Ah, OK. These were actually a different set, thanks again!
            • 87E30VERT
              • Apr 2015
              • 129
              #8436
              Car: 1987 E30 convertible
              Suspension: JOM (I know) coilovers
              Wheels purchased: 16 x 8 et 20 F
              16 x 9 et 15 R
              Fenders: stock (not rolled/pulled)
              Tires: ?
              Front: I've read a years worth of this thread and think you're going to tell me 205/45/16.
              Rears: I believe you also say I can go 205/45 here too but that's a bit too stretched for my taste.
              Can I run 215/45 without modifying fenders in the rear? What about 225/40?
              Thanks in advance.
              Early Model Front License Plate Filler for Sale: http://www.r3vlimited.com/board/showthread.php?t=363721
              Late Model Front License Filler Plate for Sale: http://www.r3vlimited.com/board/showthread.php?t=365118
              • Mystikal
                • 9602
                #8437
                16 x 9 et 15 R
                Tires: ?
                Thanks in advance.
                Nope, without a roll 205/45 is the limit. 215/40 works also but is TINY.
                • Js2010
                  • Jul 2015
                  • 6
                  #8438
                  3-5mm front.
                  No.
                  If they did before.
                  If there were before.
                  If the wheels require them.
                  I forgot to also ask, what would be the maximum tyre sizes I could fit front and rear?
                  • ginger1340
                    • Jun 2015
                    • 167
                    #8439
                    I have a 1984 325e. Stock suspension
                    How wide can I go for the wheels I want without rubbing or rolling my fender? I found some 15x8.5 that like but some people say that I would have to roll my fenders
                    • darvo
                      • Dec 2010
                      • 407
                      #8440
                      E36M fitment on front, e30m on back. Late model. 17x9 et35 front or 17x8.5 et30? What tire option do i have for these? Rear will be 17x9 et22, Ge Coils cut perches
                      • mbonanni
                        • Sep 2011
                        • 6236
                        #8441
                        1988 325ic
                        17x8 et2 front
                        17x9 et6 rear
                        Can this be ran with 205/40 front and 215/45 or 215/40 rear, with a roll and pull? Will be lowered on coils, but not super low.
                        Same car
                        16x8 et5 front
                        16x6 et3 rear
                        Can 205/50 work on these with a similar roll and pull for the set above?
                        • Mystikal
                          • 9602
                          #8442
                          205/45 is best.
                          • Mystikal
                            • 9602
                            #8443
                            Depends on the offset. And if you're stretching the tires or not.
                            • Mystikal
                              • 9602
                              #8444
                              17x8.5 front, should fit a 215/40 with stock upper mounts or 235/40 if you have camber plates dialed up a bit. Rears are limited to 215/40 if you want no rubbing.
                              • Mystikal
                                • 9602
                                #8445
                                Originally posted by mbonanni
                                1988 325ic
                                17x8 et2 front
                                17x9 et6 rear
                                Same car
                                16x8 et5 front
                                16x6 et3 rear
                                Offsets too low all around with those. Once you get into single digit offsets, 195s are the safe bet and 205s are pushing it. It really depends on how much pulling you want to do also. 205/40/17s all around and 205/45/16s are my recommendation, which isn't ideal for looks but necessary for fitment.
