This is a sticky topic.
    90 325is with ksport coils
    rear: 16x9 et20, currently running 215/40/16 with 5mm spacers.
    I really want to move up to 225s on the rear, but 225/45s are laughably difficult to find. can I remove my 5mm spacer and run a 225/50 on the 16x9 without rubbing? I have some basic fender rolling done, but the 215/40s with the 5mm spacer rub with enough load.
      Looking at 15 x 8.5 wheels, any recommendations on tire size?
      Sent from my SM-G930V using Tapatalk
        Originally posted by Das Delfin View Post
        Hi Jay. Thanks for being here after all these years. I have a question about tire size for a 16x7.5 et20 wheel.
        I see most people run 205/45 but 205/50 has a more similar rolling diameter. Any difference in fit? Car is on H&R sports. Convertible with lower rear arches
        Thanks!
        I try! I wish I could stop by more often but life is seriously in the way.
        205/50 is the correct and more popular size. 205/45 is for stancey fitments.
          Originally posted by Jimmy85'E30 View Post
          I have a 87 325is I have 20mm adapters for my style 5's 17x8 et20 with solid offset control arm bushings. What size tire can I run the front and the rear has 12mm solid riser bushings for the subframe there for less camber. Im also running H&R Race Springs. I have roller fenders.. I plan on drifting and aggressively driving the car so NO RUBBING ALOUD!!!!!!!!! lol
          You definitely bought the wrong wheels then. They don't fit properly at all, and will rub.
            Originally posted by Best_name_available View Post
            Okay guys, I need to know how much spacer I need. I ordered a set of kamotors ultrawides so I'm not too worried about poke, but here's the question. The wheels I got are a 17x10 square setup with a +15 et. I already run a 5mm spacer up front to clear basketweaves on my coilovers. What size spacer will I need to fit the fronts?
            15mm front spacers.
              Originally posted by PogiMonster View Post
              I'm looking at possibly running a set of klutch sl1's in a 15x8.5 et17 spec. What tire size would be best? Ideally I'd like to run a thicker sidewall 50/55? Thoughts? My car has the gc coilover spring kit/bilstein sports. Thanks in advance!
              205/50 for sure.
                Originally posted by Steve Corbett View Post
                4x100 to 5x120 18mm adapters, 89 325I on H&R Sport Springs w/Bilstein Sports. Looking at E38 Style 5's 16x8 wheels. Will they fit with without rolling fenders? Tire size?
                Need to roll fenders and run 205/45s. Will still rub occasionally. Not a great fitment.
                  Originally posted by perVert View Post
                  I just bought an 87 325i very and will lower it with h&r sports with Billy sports. Can I put esm 002s 16x8 et20s with Kumho Ecsta AST Ku25 205/50r/16 without rolling fenders or rubbing?
                  Should just squeeze by without rubbing. I'd suggest ANY tire but ASTs though, they are seriously awful.
                    Originally posted by gotane30 View Post
                    looking at buying Klutch SL1 16x8 et15 (front) and 16x9 et20 (rear).
                    85 325e on GC coils.
                    What size rubber should I run to avoid rubbing/fender rolling/stretch?
                    and will I need spacers?
                    Not possible without both stretch and rolling. 205/45 front 225/40 rear, rolled rears.
                      Originally posted by alas View Post
                      Ok - looking to see if I can run this set up without needing spacers on my 1989 325i with a small roll in the rear. Currently on Billy/H&R spring combo. This will probably change.
                      15x6.5 et 32 on a 205 tire
                      or
                      15x6.5 et 32 on a 215 tire.
                      I calculated max back space for 15" is 131mm and with tires about 129mm. Seems like if i ran 215's and they were really 215mm, I'd have issues. Can you confirm?
                      Thanks
                      Paper thin strut clearance. 205/50 will work, 205/55 will probably touch the struts.
                        Originally posted by Tree25 View Post
                        Want to know if or what ill need for this setup to fit my 87 325is
                        Front Wheels: 16" x 8"
                        Rear Wheels: 16" x 9"
                        Bolt Pattern: 4x100 /114
                        Front Offset: 20 ET
                        Rear Offset: 15 ET
                        Center Bore: 73.1
                        Sent from my SM-G928V using Tapatalk
                        205/45 front, 215/45 rear, rear roll. Hubcentric rings.
                          Originally posted by Bones566 View Post
                          1987 325es. Koenig feather 16x7. Offset +35 what's the max tire size and will it handle any drop springs if the tire size is reduced from max.
                          Bad offset, won't work without spacers.
                            Nope. And you live in America, land of internet purchasing. Nothing is difficult to find!
                              This is about 20% of the info I need. See the first post.
                                Thanks Mystikal! I appreciate your time and knowledge.
                                Do you know where and what size hubcentric rings? Never heard of these before
