	This is a sticky topic.
 Alright,
 What would be the ideal tire set up to run on a Kosie Kr6 15x8 +20 offset wheels. Full BC Coil set up. S52 swapped car, looking to go fast and not do much to make everything fit.
 Do I just run my iX weaves and stop trying to fit lighter wheels?Comment
 I wouldn't expect lighter wheels to have a noticeable impact on these cars. 15x8 et20 works well and fits a 205/50, should fit 205/55 too which is nice cause then your speedometer will be accurate. 225/50 might fit, but most tires in that size are for the track.
 Personally, I would run whatever wheel I like the best on the car without worrying too much about the weight. Just my .02.
 Sent from my iPhone using Tapatalk1988 E30 325iC
 sigpicComment
 I have an '87 325is (early model rear arches), slightly lowered on GC 440/650. The rear lip looks to have been completely cut flush by the PO, there is nothing there. Wheels on the car from the PO are 15x7 +15 f/r with 205/50s in front and 225/50s in rear, no rubbing whatsoever, even completely slammed previously.
 Would I be able to run Fifteen52 Formula TRs in a:
 -16x8 +20 front with a 225 tire
 -16x9 +30 rear with a 235 or 245 tire?
 Would I need any spacers with those offsets? I could also choose from a +20 rear, but I'd assume a +30 would allow for more tire in the rear, correct?Comment
 3mm front spacers and 205/45 tires.I bought a set of 16x9 ESM 002R (offset et15) wheels for my E30. I'm planning on dropping it around 2.5". Do you have any tire recommendations? I'm having trouble finding tires. I'm not opposed to stretching but I don't want anything crazy. I was thinking 225/45 but there are not many choices.Comment
 40mm adapters to clear the struts. Once they're out that far, fitment is near impossible. Could work with a 195/45 or 205/45 with pulled arches.Comment
 Yes with your existing tires, no after you upgrade to the larger sizes listed.Jay,
 Did some searching through this thread and couldn't find exactly what I was looking for. Currently running Konig 15x8 et22 with 205/50r15 all around on Bilstein sport springs and shocks and M3 offset CABs on my 88 vert. Can I get away with 5mm spacers in the rear without rubbing and in the future would I be able to fit 205/55s and/or 225 tires?Comment
 The BFGs are the best overall tire there, followed by the Kumho/Yoko as a tie, then the DZ102 as a distant last place.1989 325i. Billy shocks and H&R sport springs. e38 style 5 16x8 wheels. 18 mm front and 20mm rear adapters. Probably getting 205/45/r16 tires and rolling fenders. Which tires fit the best, last the longest, and perform well? Dunlop DIREZZA DZ102, Kumho ecsta ps31, yokohama s-drives, or BF-Goodrich G-force sport comp 2?Comment
 Should just barely work with 195/55/15 tires. Very aggressive fitment.Love these wheels, but finding mixed answers regarding fitment. The ones I am looking at are 15x8 et10 all corners. I have an '87 325 cabrio, H&R springs, KYB shocks. I do not want to roll any fenders, just looking for a retro, unique setup for my car. Will they work and what tire size would be needed?Comment
 The rears are just too aggressive. With just front spacers and none in the rear, 205/45 all around can be fitted.I have some 16x8 etc 23 and 16x9 et 14, I'd like to put on my car. I'm looking to add a 15mm spacer to the 16x8 and a 10mm spacer to the 16x9.
 What's the biggest tire size I could run, to have minimal rubbing under the fenders. My fenders are already all rolled and I'm coil overs with camber plates.Comment
 Yes. Back them down to 2.5/3":
 16x8.5 et6
 16x9 et10
 That's perfect. Tell Paul I said hi! He built me an awesome pair of custom inner barrels for my one-off Speedlines. Great guy/service.Comment
