This is a sticky topic.
  • RichiesE30
    • Jul 2016
    • 37
    #9061
    Will these fit? New e30 owner
    Just wondering if these will fit. Pretty positive they will but I wanted to ask and make sure. Seems like a pretty solid deal, will hopefully get them for a little less possibly. I have an '87 325e. Thanks.
    Last edited by RichiesE30; 08-30-2016, 05:25 PM. Reason: forgot to add model of car. figured it might help
    • Chroma Aberration
      • Mar 2016
      • 78
      #9062
      Will it fit (it should)?
      Hankook RS-3 in 225/45/15
      On 949 6UL 15x8 +36 offset, 67.1mm bore wheels
      On my 325iX, lowered ~1.3 inches on bilstein HD + h&r sports.
      On stock and very dirty baskets with 205/50 toyo proxes:
      91 325iX - magnaflow, h&r sports+bilstein hds, chip
      • Mystikal
        Wheel Fitment Expert
        • 9602
        #9063
        Originally posted by RampageRR
        Awesome, thanks for the reply. I may just end up going 16x8 all around with 225/45 to be safe, but I do have one more question if you don't mind.
        You say 24.4" or less is ideal for an E30 tire - is a 245/45/16 too tall at 24.7"? I only harp on the wider rear because I'll be swapped with either an LS or S54 by nexf year, so I'd rather get as much tire in the rear if at all possible. Not the end of the world with 225, but any extra would obviously help.
        Up to 25" will work in the rear-only. I've seen 245/45/16 work with a suitably high-offset rear wheel.
        • Mystikal
          • 9602
          #9064
          Originally posted by Js2010
          Hi great thread.
          I have put borbet A 16x9 et15 front and back. With 3mm spacers on the front with standard bolts. 215/40/16 all round.
          The car has completely standard suspension. I now need to lower the car.
          I looked at a cheap JOM coilover kit, which uses the standard struts. The wheel does not touch the strut. If lower the car with above kit will my wheels still fit or start rubbing somewhere?
          If I get another coilover kit which changes the strut will do you think I will have more issues?
          No issues with JOM nor BC, or GC. Just make sure for the latter two the front springs are 6" or shorter.
          • Mystikal
            • 9602
            #9065
            Originally posted by BMWALEX
            Hello. I have a 1987 32e coupe. Stock ride height.
            I bought a set of felgenwerks classicos
            15x8 +25
            15×9 +15
            Hub bore 73.1
            What size tires is the max i can install without rolling fenders? What do u recommend? And do i need spacers?
            3mm front spacers. 205/50 is the largest rear tire that will fit. I'd suggest that all around, or 195/50 fronts to stagger a bit.
            • Mystikal
              • 9602
              #9066
              Originally posted by stanhayward
              Yokohama S.Drives in 175/50r16 and 195/45r16 sizes and the most aggressive roll of your life. *puts up umbrella for following shit storm*
              You're entirely correct though!
              • Mystikal
                • 9602
                #9067
                Originally posted by ricksifuentes
                I already purchased 17x8 and 17x9 wheels with et25....what are my options as far as tires or should I change width on tires my car is completely stock 1991 318is
                Oh man those are perfect. 235/40/17 can work all around with a rear fender roll.
                • Mystikal
                  • 9602
                  #9068
                  Originally posted by pepperjackdaisy
                  Thanks for the info, but I think I've moved to another option. Again, E30 cabrio, KYB and H&R Sports. She sits a bit lower in the 2nd pic, since the springs have settled.
                  ESM-009 16x7.5 ET18 4x100 CB57.1 Lip Size 3.0" Gun Metal/Polished Lip - Front
                  ESM-009 16x9 ET15 4x100 CB57.1 Lip Size 4.0" Gun Metal/Polished Lip - Rear
                  Any fitment issues here? Tire sizes with no stretch, and little to no speedo errors?
                  Issue is the rears are way too aggressive to not use stretched tires. 205/45 all around would be best for those.
                  • Mystikal
                    • 9602
                    #9069
                    Originally posted by ferndigity
                    89 325is tire size??? Mystical i have set of staggered wheels 15x7 front and 15x8 back et 12...what tire size can i use? currently im running 15x8 front and back et 20 with 225/45/15 all around h&r sport springs an blisteins sport ( i dont like my current wheels tho) with no problems i believe the fenders are slightly rolled....what tires can i used? thanks in advance...the bottom pic are the wheels in question...not my car tho!
                    205/50 all around would be best. 195/50 fronts if you want to stagger them.
                    • Mystikal
                      • 9602
                      #9070
                      Originally posted by Clark
                      Mystikal, 16x7.5f 16x8.5r et19
                      205/45 front 215/45 rear would be perfect. Good luck finding tires though.
                      • Mystikal
                        • 9602
                        #9071
                        Originally posted by DarkWing6
                        17x8 ET34 on a late model sitting on IE3s. Fenders aren't currently rolled but could be.
                        What size tires should I run? Spacers needed?
                        I'd run 10mm spacers all around with 235/40/17 tires and a rear roll. You could also do 15mm all around with 215/40 tires and no roll.
                        • Mystikal
                          • 9602
                          #9072
                          Originally posted by White325is
                          Early model coupe with z3m rear 5 lug and e36m fronts. 18" is the smallest wheel that can be fitted due to the brakes. So what width and et do you suggest with running a "normal" size tire.
                          A 18x8.5 with a 225/35/18 would be ideal. As for offsets, I'm really not sure. So many variables there that I can't say anything with confidence unfortunately.
                          • Mystikal
                            • 9602
                            #9073
                            Originally posted by NC325iC
                            Mystical, do you have any recommendations?
                            Sorry, haven't look at tires in that size in years.
                            • Mystikal
                              • 9602
                              #9074
                              Originally posted by 89DirtyE30
                              i recently picked up some trm 15x7 et25 wheels. Ive got 205/55 15s on the car right now, but would like to go wider. Ive heard 225 45 or 50s are about as wide as you want. Biggest question is who makes a decent tire in those sizes. Mostly for daily use with occasional autocross. Supercharged m20 laughs at my crappy 205s.
                              Pretty much everything made in 225/45/15 is ideal for auto-x. There's probably two choices and they both rock. Check tirerack.com
                              • Mystikal
                                • 9602
                                #9075
                                Originally posted by ST1G
                                You're saying I can run that wheels size on the front at all?
                                EDIT. To make it easy, my 16x9 +25 modern lines.
                                I'm saying "meaty" can't. 205/45 all day.
