This is a sticky topic.
  • JRKOUPE
    • Dec 2004
    • 3159
    #9091
    depends on how u drive.....
    but 225/50 15 looks good......and works.......nice comfy sidewall......
    esp w/ 8 inches
    the s52 is not really the deciding factor....its more what you are after?.....your goals?..looks stick etc etc...stance
    • atsbmsmith
      • Sep 2016
      • 3
      #9092
      Best Tire Size for 87 325e
      Ordered a set of 15X8 AVID.1 HYPER SILVER WHEELS AV-12 4X100 +25. Looking for the best tires size that does not looked stretched and if possible does not require rolling the fenders. H&R Sport Springs with Blistien Sport shocks.
      • NC325iC
        • Mar 2004
        • 6565
        #9093
        esp w/ 8 inches
        225/50/15 is what I have now. They're a bit hard to find.
        Sent from my ONEPLUS A3000 using Tapatalk
        • Zeemz
          • 485
          #9094
          1990 325is
          BavAuto springs
          Bilstein Sport shocks
          Interested in a set of BBS RM 012 15x8.5 with 2.5in lips. Based on the stamp the original ET was ET33. http://forums.vwvortex.com/showthrea...-rm-012-15x8-5
          I found this post on Bimmerforums that helped give me the modified offset due to the changed out lips.
          "Here are the offsets for a BBS RS, just subtract 1 from the et's to get the RM's:
          1.0” = 15x7 et 27.65
          1.5” = 15x7.5 et 21.3
          2.0” = 15x8 et14.95
          2.5” = 15x8.5 et 8.6
          3.0” =15x9 et2.25"
          So I think the new offset is 7.6.
          So to run a 225/45/15 or 225/50/15 do I need a spacer and what size?
          Thanks for the help. I am clueless when it comes to calculating proper offsets. I saw a couple threads noted 15x8 would fit a 225 with a ET20 without rubbing. Not sure how the extra .5 of an 15x8.5 would affect it. However I saw another post of someone running the same wheel with no spacer in the back and 8x15 in the front with ET14 http://forums.vwvortex.com/showthrea...-rm-012-15x8-5
          1989 325is Lachssilber - Sold
          1990 325is Sterlingsilber - Current Project
          September 2018 Car of the Month: Zeemz
          Youtube Track & Autocross Videos
          • dvallis
            • Oct 2015
            • 1472
            #9095
            Offsets for 17x9 245/40/17 Square Setup
            I'm considering running a 17x9 245/40/17 square setup on Das Beast.
            Looking for input on the proper offsets, front and rear.
            Bodywork clearance is not an issue. I can chop, grind or add flares. Mainly concerned with suspension interference.
            Running 15x7 TRM C1 ET25 with 205/55/15 now. Clearance between the front suspension and tire sidewall is only 12mm.
            Clearance between rear tire and suspension is 50mm.
            My calculations using this web site say I should be running offsets of 5-ET front and 25-ET rear.
            Looking for feedback.
            "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
            1987 E30 3L Turbo Stroker Das Beast
            2002 E39 M5
            • Daemonblitz
              • May 2016
              • 78
              #9096
              Hey Jay, we've met before, I'm not sure if you recall. Your Z would always come out on top in Bimmercruise and I'd get runner up for our class :p :)
              I am helping a close friend with his E30 build.
              This is our progress thread here. http://www.r3vlimited.com/board/showthread.php?t=395205
              We are looking into wheel/tire options.
              The car will have 5 lug conversion (E36 M3 front and E36 318ti rear) and converted to M3 body.
              Also we are running GAZ coilovers.
              We already know that we will have to run an 18" rim due to the big brakes.
              We are hoping to run as wide of a tire as possible paired with a wide rim (staggered setup) but want to avoid any kind of rubbing.
              Looking to see what advice you can give on this.
              E86 ///M Coupe - Imola Red/Imola Red
              E90 330xi - Titanium Silver/Black
              K46 S1000RR - Matte Red
              Follow the E30 Build thread
              • Mystikal
                Wheel Fitment Expert
                • 9602
                #9097
                Originally posted by Nick_e30
                I had this test fitted today and it cleared the strut but barely maybe like an 8th of an inch. Is that okay or should I use a 12mm instead of the 10
                Sent from my SM-G930V using Tapatalk
                You're more than okay.
                • Mystikal
                  • 9602
                  #9098
                  Originally posted by MattRFact
                  Probably been asked 100x on this thread but here I go.
                  BBS Rc090 17x8 5x120 et20 with 18mm 5 lug adapters
                  I need the tire size for a 93 e30 vert dropped on vert H&R sport and Bilstein shocks. Also, what fender work would I need. Thank in advance.
                  195/45s and rolling all around. Might still rub a bit. Bad fitment IMO.
                  • Mystikal
                    • 9602
                    #9099
                    Originally posted by af dynamic
                    Please help, going to install a coilover tomorrow and not sure if I need to roll the front fender? Rear Rolled already.
                    16x8 Front 20 ET 205/45/16 Front
                    16x9 Rear 15 ET 215/45/16 Rear,
                    For 1990 E30 Sedan
                    No front rolling needed.
                    • Mystikal
                      • 9602
                      #9100
                      Originally posted by sfe30stoner
                      hey mystikal, thanks for all of the hard work on this thread over the years. Just read about 50 pages worth.... Good stuff!!
                      Anyway, on to the fitment question.
                      Late e30 coupe on h&r sport springs and billy hd shocks - factory fenders (no rolling)
                      16x7 et20 bbs rs replicas w/ hubcentric adapter rings (no spacers)
                      what is the maximum square tire sizing that is safe to run on these to avoid rubbing?
                      Thanks!
                      Gabe
                      205/50r16
                      • Mystikal
                        • 9602
                        #9101
                        Originally posted by Eric
                        Do you think 16x9 et 30 (spacer can be added) and 225/45/16 would fit up front? Probably a degree or two of camber, but nothing crazy.
                        Needs about -3 camber to work. 18mm spacers are ideal, 20mm is workable.
                        • Mystikal
                          • 9602
                          #9102
                          225/50R15 or 225/45R15. 5mm front spacers.
                          • Mystikal
                            • 9602
                            #9103
                            Originally posted by Zeemz
                            1990 325is
                            BavAuto springs
                            2.0” = 15x8 et14.95
                            3.0” =15x9 et2.25"
                            Correct, +8 or so. Even a 205/50 will require rear fender rolling. Stretch is necessary for that fitment.
                            • Mystikal
                              • 9602
                              #9104
                              +10 front +30 rear would be perfect. There is enough room inside for these offsets.
                              • Mystikal
                                • 9602
                                #9105
                                What's up man. Love your Imola Z4M. F15 brakes? That's a damn cool project.
                                Because of the combination of E36 5-lug and E30 M3 custom bodywork, I really can't say for sure what offset and width combination will be ideal on that car. I'd try to find some 8.5" or wider factory wheels and do some test fitting once the bodywork is done. X5 wheels, E60, E46 M3, etc whatever you can find laying around that's reasonably wide. The diameter will be too tall but it will give you an idea of what offset range to shoot for. Wish I could give you an exact setup to run but with all of those variables combined it's not possible for me to do it. Good luck!
