	This is a sticky topic.
 20mm front 25mm rear should just work. 15/20 would also look nice and cost substantially less.Comment
 You will be limited to 215/40s in the back, so use that to decide what to run on the fronts. I'd probably go 205/40 215/40 staggered. They will fit flush.Comment
 17x8 +25 235/40 frontHave a turbo build in the works, and am in search of traction. Willing to roll (and maybe pull) the fenders the car isn't slammed, but it is low.
 17" wheels; what offset and width will allow the widest tire?
 What will that tires dimensions be?
 Would love to fit 255's in the back maybe 225's up front?
 17x8.5 +30 245/40 rear
 Should only need a roll in the back.Comment
 Your rear springs are indeed too soft. You shouldn't have that much deflection. I've setup E30s with 2" of oil pan clearance and 16x9s that still don't touch that pinchweld. Definitely look into swapping springs.Sorry I can't find any info in my searches, but what do you guys do about the nubs in late coupe rear wheelwells? You know, those ones up top inside wheel well lip?
 I don't feel my rear fitment is even that aggressive, 205/50R15 on 15x7 et12 with just over a degree of negative camber and the outside of my tires rub on those sheet metal nubs in the upper/inner wheel wells on my late coupe, on hard cornering, really uneven driveways and under hard acceleration. Lips are rolled as much as I could using a borrowed Eastwood roller but I stopped when it was apparent it was as good as it was getting with those bumps still in there. You guys know the bumps I'm talking about? What do you guys do to get rid of those? I had one suggestion but want to hear more.
 Or am I just too damn low? I have some mystery ass lowering springs in the back of my car, it seems to squat a lot, should I ditch the rears for something stiffer and adjustable-height like the GC rear setup? Give it a slight rake (car sits higher in front now than in my sig pic) with more rate and it becomes a non-issue? I'm actually trying to put small spacers in the rear to make it look as flush as my fronts where I have to run 3mm spacers to clear the calipers.
 ThanksComment
 Hmmm. The Z3M has exceptionally short axles, but I'm not sure how short they are compared to stock E30s (or more specifically, the track width difference between the two). I have a hunch he will need a low offset to make it work, but I'm honestly not certain. Test fitting with various wheels should give a quick idea of what to look for.good day Jay, an interesting 1 for you, or maybe not I guess, lets see.
 a friend has an early 2door with Mcoupe complete rear end setup. he wants to fit style 32's in 17inch. front is still fitted with 4x100 and a big brake upgrade. adapters will be used to get the front to 5x120.
 now the interesting part, style 32's come in different widths. which sizes would you recommend for wheels front and rear, and again what tyre sizes would you suggest. arch lips are rolled flat and the car is on coilovers, and has an mtec1 kit.
 any other ideas or suggestion are welcome too.
 Tx in advanceComment
 I'd go to 9.5". Add 1.5" to whatever the inner barrel is now. The new offset would be +30, making them an ideal +12 final with adapters.Looking to buy a set of RS's, specs are as follows.
 Fronts : RS005 16x7 et11
 Rears : RS211 16x8 et11
 I'm running 18mm adapters so the fronts will be fine but the rears won't.
 What barrel or barrel/lip combo can widen the rears to a 16x9 wheel and correct the offset to have a flush fitment with my adapters?
 Also, once you know the barrel sizes look into possibly swapping that existing rear barrel to the fronts. Maybe you can help the fitment of those a bit.Comment
 First setup, yes. Use 205/45 tires.
 Second setup, sort of. 3-5mm front spacers, 205/45 tires, and a rear fender roll.Comment
 I am looking for a tire size...I want to run as much tire as possible without pulling the fenders/rubbing.
 1989 325is
 Suspension
 Ground Control Street kit Coilovers
 Nasieg 5-lug conversion
 Front
 e36 M3 front hub (Pushes out +12mm)
 Rear
 z4 Hubs (Pushes out +2.5mm)
 Wheels
 e38 16x8 Style 5s Et23
 Essentially makes front wheel et11 and rear wheel et20
 What is the meatiest setup I can run?
 Thanks!Last edited by VBe30; 12-04-2016, 07:06 PM.Comment
