This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #9376
    Originally posted by rob0589
    I am currently purchasing esm 002's staggered 16x8 F(20 offset) 16x9 R(15 offset). What size tires are my best bet. Also, do i need spacers for the fronts or rears?
    205/45 all around. No spacers.
    • Mystikal
      • 9602
      #9377
      Originally posted by parkerbink
      How well will these fit on a mostly stock '92 e30 Cabrio? 16x7 +30 4x100 Sparco Terra with 215/50-16 Dunlop Direzza DZ102.
      Well. Fronts will be very close to the struts though, might need a 3mm for safety.
      • Mystikal
        • 9602
        #9378
        Originally posted by evanbenne
        Could I run a 16x8 et15 wheel with a 205-50-16 tire with no fender rolling?
        If not what can I do to run 16x8s?
        No, 205/45 is necessary for clearance.
        • Mystikal
          • 9602
          #9379
          Originally posted by hexe30
          Looking at a 17x8.5 +35 offset. What can I do to get to them to work?
          15mm spacers all around, 205/40 tires.
          • Mystikal
            • 9602
            #9380
            Originally posted by Chrisv006
            Could I run BBS style 29's with 18mm 5x120 adapter on a 1990 convertible, lowered about 1.5" with no rolling? What tire size would work?
            What offset and with are they?
            • Mystikal
              • 9602
              #9381
              Originally posted by E30_Kyle
              Looking to get a set of wheels. I plan on running 15x8 +38 in the rear and 15x7 +25 in the front. What size spacer/tire should I run for an aggressive fitment?
              15mm front 20mm rear. 195/50 front 205/50 rear.
              • Mystikal
                • 9602
                #9382
                Originally posted by LateE30
                welp. i suppose it does NOT fit...sad day.
                Rears fit GREAT, couldnt be more perfect. However the fronts stick out a good amount from the fender AND they are rubbing the struts.
                Going to get 5mm spacers and extended bolts. See if it at least fixes the clearance issues. i think a lower profile tire will be more useful as well, thinking a 45 or 40 instead of the 50mm.
                I think it's going to look pretty terrible sticking out 5mm more up front
                12-15mm front spacers and 205/45 tires all around. It'll poke without camber plates and not match the rear at all, though.
                • Staszek
                  • 2533
                  #9383
                  Originally Posted by Staszek View Post
                  16"x8" ET29. Tires are 225/45R16.
                  What size spacers front and rear? 1990 325is on H&R Sport.
                  Originally posted by Mystikal
                  10mm front hubcentric. Rears can work with none at all, up to 5mm works without fender rolling. 10mm if rolled flat.
                  So if I wanted to get close to flush without rolling what would you use? could I go front and rear?
                  10 front and 5 rear for my 225? could I go 10mm and 8mm?
                  • LateE30
                    • May 2017
                    • 210
                    #9384
                    Thanks mystikal.
                    how about 16x8 et25 all around?
                    '87 Vert, Black, 5-sp
                    '15 Civic Si, White - Daily commuter
                    '15 MB C300 Sport, White/Cranberry - Wife's
                    • parkerbink
                      • Jun 2004
                      • 10137
                      #9385
                      Thanks
                      • starscre4m
                        • Jun 2014
                        • 1
                        #9386
                        Hi!
                        I bought some BBS RS's in 16x8.5 et20 and 16x9 et8. I have 195/45 front and 205/45 rear tyres.
                        The car will be on bags soon and I'm just wondering what size spacers i should get in order to get the wheels close to lip to fender when aired out.
                        Thinking of getting 20mm front and 5-10mm rear.
                        using e30m3 5 lug hubs if it makes any difference.
                        Thanks! :)
                        • Chrisv006
                          • 375
                          #9387
                          16x8 et23 e38 Style5's with 18mm adapters on 1990 cabriolet? I would like to lower the car with HR Sports.
                          • Buzz944
                            • Apr 2017
                            • 21
                            #9388
                            Hey guys complete noob here
                            How will these fit
                            F 17 8.5 et15
                            R 17 10.5 et22
                            I have a feeling they're not gonna fit
                            • Buzz944
                              • Apr 2017
                              • 21
                              #9389
                              Fitment
                              How will these fit
                              F 17 8.5 et15
                              R 17 10.5 et22
                              • rob-redm
                                • Feb 2013
                                • 420
                                #9390
                                Hey there Mystikal,1986 BMW 325ES. I have a set of BBS LM's (real deal) 17 X 7.5 with a et 40mm off set... running a 205/45-17 Dunlop Direzza tire.. know I'm going to need spacers to make them clear the front and look right on the car (front and rear )due to the offset...and longer lug bolts also... car has a E30 Bilstein Sport Shocks - E30 (set of 4) T#3714 & H&R OE Sport Spring Set - E30 - 318is 325e 325i 325is M3 T#4342(the springs were rated at lower the car a 1"... whats your thoughts... Thank you...
                                Well wanted to get the new rollers on my ES for the e30 picnic, went with H&R DR spacers 57.1 bore 15MM front spacers & 20MM rear spacers..my guess work came out ok... looks darn good !.. HMM do I keep my 15 BBS RS wheels as back ups... on the fence on selling those..
                                Last edited by rob-redm; 06-23-2017, 09:17 PM. Reason: wheels on , did my own spacer work
                                it's just a ETA !
