This is a sticky topic.
  • almostacrayon
    • Nov 2012
    • 157
    #9481
    I just saw the work equip 40s.
    Would anyone be able to help with choosing the appropriate offset in 15x8/15x9 size?
    Link to the spec sheet --> http://www.work-wheels.com.au/files/pdf/equip-40.pdf
    Also would you think I would be able to run a bbk if I went the standard or big brake barrel choice?
    • MikeM
      • 583
      #9482
      Setup: Koni SA, ie3 race springs, e90 hats, gc sport camber plates.
      Desired wheel: 15x8 et20 all corners (trm c1)
      Question: What’s a good tire size that won’t rub? 215/45/15? 225? 50? Also, will I need spacers and if so, what size? Thanks!
      1990 325i Coupe
      ///PNW e30 CREW
      • hakstern
        • Sep 2017
        • 195
        #9483
        Is 16x8 et7 all around too aggressive? I’ll be running 215/45/16 tires with a slight roll all around.
        Original wheel is 16x8 et32 but will be running a 25mm adapter
        Suspension: coilovers
        • 325e '87
          • May 2017
          • 503
          #9484
          Beyern mesh
          I really like the Beyern mesh style wheels and I have them on my ‘89. They were on the car when I got it.
          My son wants them on his ‘87. They are 15x7 and both the cars are stock suspension.
          Are all the Beyern mesh wheels the same offset/backspace?
          Can we go up to a 16”? Or, are there 15x7.5 or 8?
          I’m not finding any info really, from what I can tell if you want a Beyern mesh you don’t get to pick and choose between different widths?
          My son has the 1987 325e, 2 door, 5speed
          I daily the 1989 325i, 4 door, 5speed
          • Jake325is
            • Jan 2017
            • 84
            #9485
            Looking at a set of e38 style 5s with 205/50 tires, can i use adapters or do they have to be filled and drilled?
            • Staszek
              • 2533
              #9486
              With 205 you can use adapters, although they will be pretty aggressive at ET5
              • Jake325is
                • Jan 2017
                • 84
                #9487
                Okay thank you!
                • roznic
                  • Mar 2013
                  • 2873
                  #9488
                  Late e30 5 lug swapped on coilovers: front e36 m3/rear 318ti
                  Style 32's 8"x17" et20,
                  Can I get away with 215/35 tires, don't like to stretch too much?? If someone has pics would greatly appreciate...
                  Also,
                  Style 23's M-Contours 8.5"x17" et41 all around, which spacers, tires and studs length recommended?
                  Thanks in advance!
                  • roznic
                    • Mar 2013
                    • 2873
                    #9489
                    Also,
                    Thanks in advance!
                    bump, anybody?
                    • roznic
                      • Mar 2013
                      • 2873
                      #9490
                      C'mon gurus, I'm sure somebody has at least attempted to try this^^^
                      Please chime in, I've browsed through 200+ pages but just too much too read here lol
                      • CharMick
                        • Aug 2016
                        • 56
                        #9491
                        Staggered Style 18
                        I have a shot at some cheap Style 18s on CL. $200 asking.
                        17x7 front and 17x7.5 rear, all are ET41.
                        If I get them I'll probably get 4-5 lug 18mm adapters. I tried looking for pix of these wheels mounted on an E30 but I'm not finding any. Is there a reason these wheels wouldn't work on an E30 with spacers?
                        Car is a stock height 92 cabrio that has an M30 swap.
                        Thanks!
                        • Lenwood
                          • Mar 2012
                          • 100
                          #9492
                          New combo
                          16x8 style 5 off 90’s 7 series. H&Rcup kit. Wanna go to either a 205/40/16 or 205 45 16. Will I need to roll my fenders?
                          1989 325ix(sold)
                          1989 325i sedan s52 powa (current)
                          • Staszek
                            • 2533
                            #9493
                            I’m running them right now drilled and filled no spacers and 225/45r17. Those two sizes you put are way small. If you want to run a 205 you should go 50 series.
                            • roznic
                              • Mar 2013
                              • 2873
                              #9494
                              Also,
                              Thanks in advance!
                              Bump
                              • roznic
                                • Mar 2013
                                • 2873
                                #9495
                                The gods have left the building...
