	This is a sticky topic.
 17x8+14 17x8+19
 also
 17x9+22
 and
 16x9 et 15
 on a car with ie3's no spring pads. Id like the wheel as close to the fender as possible. I would also like minimal wheel gap i dont mind running a bigger sidewall. The stretched tire guys cars are low so they can pull that 205 strech look off. I am not as low on ie's so i was wondering what tire guys you recommend so that the wheels dont look empty with huge wheel gap.Last edited by e30 gangsta; 05-22-2008, 07:26 PM.Comment
 First setup: 215/40/17 is possible with a really good fender roll. 205/40/17 is a lot easier to fit, but it'll leave more fender gap.17x8+14 17x8+19
 also
 17x9+22
 and
 16x9 et 15
 Second setup: Exact same answer as #1.
 Third setup: 215/45/16 for more fender filling. You'll need to roll the rear lips here.Comment
 -Erik
 Originally posted by 87e30I just want to dance with some beeziesComment
 I figured he knew that he needed them on the front. If you want to put any spacer on the rear, getting a tire that isn't really undersized will be an exercise in fender pulling. The 215/45 will be a bitch, I'd go 205/45.Comment
 Ok, I read thru the thread and I have one more question. The wheels are 17x7.5 et 33. I got 8mm HR spacers ready to go all around and I've read that the tire should be
 215 40 17. My fenders are already rolled. I am also on IE3's. Can I put a wider tire on the rear without the spacer on the back without rubbing?sigpic
 Yes, you will be able to run a 235/40/17 with that setup. Be careful with those spacers, especially on the front. They are 90% chance going to leave you with not enough of the hub for the wheels to sit on, which will lead to vibrations as well as overly stressed bolts. This is why I never recommend 8mm spacers.Ok, I read thru the thread and I have one more question. The wheels are 17x7.5 et 33. I got 8mm HR spacers ready to go all around and I've read that the tire should be
 215 40 17. My fenders are already rolled. I am also on IE3's. Can I put a wider tire on the rear without the spacer on the back without rubbing?Comment
 Jason,
 We need a list of people who make decent spacers for e30s no? I see many spacers that overshoot or miss the mark, being either too large and hitting the brake pads or too small and not covering the whole surface.
 - ErickErick Mahle | FullOpp Drift | YouTube
 ..::Support FullOpp::..
 FullOpp Stickers for sale!
 Feedback Thread
 Originally posted by Mr. Anderson...one of the most hardcore E30's around. :DComment
 I was wondering, I have fairly extensive fender work on all corners, what tire could I run to get some more meat on the ground. I'm running 16x8 et15's front and rear and I'm on eibach race springs. Non coilover eibachs. So what could I fit?
 As of now I'm on 205-45s and I want a little more meat.
 Thanks
 E30_FiendComment
 yeah that's exactly what I told him too. Thanks for helping.-Erik
 The list begins and ends with H&R. Not saying others are necessarily bad, but H&R is tried and true.Comment
