Without seeing and measuring how much space you made (as well as where), I can't say what will fit. For your purposes I say either trial and error, trial and modify more, or trial and get lucky. 225/45/16 is about the biggest I can see working without SERIOUS metal work at that offset.
	This is a sticky topic.
 Thank you Jay,
 235's is really what I wanted all around. The spacers are HR but I see your point, they do not have a lip to help center the wheel. I ordered the vorshlag bolts to help with the length. Maybe I should send back the spacers and use a thinner spacer (3mm?)in the front. If I do this, can I use a 235 in the front also with the wheel offset of +33? I want the car to sit low but would rather have properly centered wheels w/meaty tires over flush fitting and possible vibration at speed. Sorry for all the questions.sigpic
 Orlando, E-Rich is pulling off 235/40/17s all around on 17x9s. It takes a bit of fender lovin', but it can be done.Erick Mahle | FullOpp Drift | YouTube
 ..::Support FullOpp::..
 FullOpp Stickers for sale!
 Feedback Thread
 Originally posted by Mr. Anderson...one of the most hardcore E30's around. :DComment
 Thanks Erick.
 This is why I like this forum.
 On the 9"s from what I've seen it makes it a little better since the tire stretches out slightly. I have a 7.5 which which from what I've read on this thread, makes the width a bit more of a issue. Fender lovin is at a minimum since I don't want to damage paint at this point.sigpic
 Oh, also: he has IE Sway bars 25/22, which I'm sure help a lot on the matter. :pErick Mahle | FullOpp Drift | YouTube
 Feedback Thread
 I pushed the fenders out about 3/8 of an inch. There was contact with the fender and tire in the rear before and now there is a finger and a half. Shitty measurement but thats what I have noticed. I have all kinds of space now that I dont have the same shitty pro kit springs. Now I have the race kit from eibach. Mush more stiff and the distance is even further now.Without seeing and measuring how much space you made (as well as where), I can't say what will fit. For your purposes I say either trial and error, trial and modify more, or trial and get lucky. 225/45/16 is about the biggest I can see working without SERIOUS metal work at that offset.
 So. . . .
 E30_FiendComment
 Depending on the shape of the exact tire used, you may not even need a spacer at all for those wheels and 235/40/17 tires. And even if you run the 8mm, you won't have to roll the fenders. Not kidding.Thank you Jay,
 I'd recommend keeping one pair of 8mm for now, and test fitting the wheels/tires without spacers. If they work, great, throw the 8mm on the rear and enjoy the huge grip. If not, run the 8mm on the front while you may have to wait for the 3mm spacers to arrive. You won't need any spacer on the rear, so this is a great temp solution.Comment
 Alright, so if (and only if) your 3/8" estimate is correct, a 225/45/16 should be no problem. It should clear by a few mm. But again, this is all banked on your measurement, so no guarantees from me. :pI pushed the fenders out about 3/8 of an inch. There was contact with the fender and tire in the rear before and now there is a finger and a half. Shitty measurement but thats what I have noticed. I have all kinds of space now that I dont have the same shitty pro kit springs. Now I have the race kit from eibach. Mush more stiff and the distance is even further now.
 So. . . .
 E30_FiendComment
 I've got new 205/40/16 tires I never use from one of my other cars.
 I have some 15x7 I was going to use on the E30 but looking at pics I think 16 may be a good size and at 7" the tires should work out right?
 Then again, 15x8 would probably be better? I've always liked 15 for the gearing, tire availability and lightness over 16s.
 Future autocross and track day use.'74 2002 - Build blog at
 nomads2002.blogspot.comComment
 7" is fine for 205/40, although I'd warn that unless the tire deals very well with heat, you may run into overheating during extended track sessions due to the small size.I've got new 205/40/16 tires I never use from one of my other cars.
 One of my favourite setups is either Rota Slipstream, 15x8 or 16x8. If you keep the tires to 215 or under you won't even have to roll the fenders, and you get great reponse from the well-supported sidewalls. You could always just run the 16x8 with those tires for now and step up to a 215/45/16 later. Sure it's a pound or two heavier, but you won't feel it.Comment
 So 205/40 has enough sidewall to work (till they are toast) on a 16x8? Hmmm, tempting.'74 2002 - Build blog at
 Share what tires they are. Because if it's something like a Falken 512 then I wouldn't drive on them at 10/10ths, but if they're anything with a reasonable sidewall you'll be more than fine.Comment
 I will go home tonight and get an exact measurement from sidewall to fender lip. Do you want me to take any other measurements? Is there anything else that would make the tire not fit?
 E30_FiendComment
 Jay,
 Back in post #826 of this monster I was asking about 215/50/15 BFG Gsports for euroweaves. I have not purchased tires yet, but have been rolling on undersized 195/60/14's for the last 2 months and the increase in gearing and how the rear end comes around (not slides, just how it turns) has been better. So I was wondering about getting a set of 205/50/15 instead. Another thing is I think I will try to find a better three season tire for the RZ's, as I have three sets of wheels and want to do stickies and snows on the others for situational use, but run the RZ's most of the time. So what do you recommend at this point? I have a S3.73 fwiw. Thanks!
 JackOriginally posted by chileelkyamaze about the enthusiasm e30 generateComment
