This is a sticky topic.
  • Erik
    • Oct 2005
    • 5370
    #1381
    E30 M3 5lug with:
    17x10 et20 rear, 235/40 tires (or maybe 245/35?)
    17x8.5 et13 front, 215/40 tires (orrrr maybe 205/40?)
    What's your take?
    -Erik
    Originally posted by 87e30
    • theox69
      • May 2008
      • 1732
      #1382
      Originally posted by Mystikal
      I guess the stock suspension height is saving you. As soon as that car comes down...it will most likely rub.
      225/50/15 isn't even remotely an option on those wheels without fender flaring.
      By fender flaring, do you mean cutting out the original fenders and bolting in wider ones?
      Or do you mean pulling and rolling the original ones...because i dont really mind doing that..
      you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
      • CrazyB
        • 420
        #1383
        Any clue if the 0 offset wheels in a15x8 or 16x8 will fit a 89 bmw with low arches and ie3 suspension. Sorry tried searching but did not find anything.
        __________________
        AutoCross Photos!!https://picasaweb.google.com/eugenes18t
        • Mystikal
          Wheel Fitment Expert
          • 9602
          #1384
          Originally posted by AlpineE30M52
          E30 M3 5lug with:
          What's your take?
          Not a chance on that rear setup. 225/35/17 with rolled fenders would be the only feasible way, without getting into flaring.
          The front should therefore run 205/40 just to keep the sidewall heights matching. Probably get away without even rolling up front.
          • Mystikal
            • 9602
            #1385
            Either one, as long as you have the skills and tools to do the second one properly.
            • Mystikal
              • 9602
              #1386
              __________________
              Either one is a really tough fitment, and looks a little odd to me (search for pics of Sportmax 002 wheels for reference).
              The guys who are pulling it off are running 195/50/15 or 195/45/16 tires and rolling the fenders.
              • aworthybrother
                • May 2007
                • 899
                #1387
                16x9
                what do you think about this? Yes or No?
                can this be fitted to an 87 325e?
                RH CUP
                16x9 et45 w/ 205/45?
                what spacers, hub centric, longer lugs is required?
                • sennasixty8
                  • Jan 2008
                  • 346
                  #1388
                  Just picked up a clean set of staggered 15" RS's for my 91 e30 on h&r/billysports....
                  15x7 +25 oem rs001's (front, no brainer for the tires)
                  15x8 +12 oem rs002's (rear, a little bit trickier, since late arches have a "mild" fender roll done to them by yours truly.....
                  can I just run 205/55/15's all around and let the 8's stretch 'em a little bit?
                  thoughts.........?
                  • sennasixty8
                    • Jan 2008
                    • 346
                    #1389
                    I'll go ahead and answer my own question after swapping the new tires and wheels on this afternoon...
                    225/50/15's FIT on a lightly rolled late model e30, with a 15x8 +12 offset wheel, even with the h&r lowering springs (sport, not race).
                    I'm not running these donuts for long, they look too balloon-ish. I'll wrap 205/55/15's all around and call it a day.
                    • Mystikal
                      • 9602
                      #1390
                      RH CUP
                      http://i23.photobucket.com/albums/b3...45ce2dfa4a.jpg
                      I answered your PM.
                      35mm spacers, which is HUGE. I wouldn't bother.
                      • Mystikal
                        • 9602
                        #1391
                        That honestly and truly doesn't fit, at least by reasonable standards. There's no way that won't rub on a large suspension movement, or even a light one.
                        • sennasixty8
                          • Jan 2008
                          • 346
                          #1392
                          Did you mean to say, that the 225's shouldn't fit, and 205/55's would be a better set-up?
                          I really didn't think that these 225s would bolt on, but they do. I took my wife out for a test ride around a few corners with dips, and it didn't rub. I have a feeling if there were rear passengers, I'd have issues.
                          Now... my question is how that 205/55 will look on a 15x8....?
                            • 34827
                            #1393
                            given that those 225s look like balloons, I'd wager 205/55 will look better.
                            • Mystikal
                              • 9602
                              #1394
                              In my opinion, it'll still look quite "ballooney". I'd back down to a 205/50, stock height 15" tires always look strange stretched.
                              • sennasixty8
                                • Jan 2008
                                • 346
                                #1395
                                put the 205-55-15's on today, and they're barely even stretched, I wouldn't even call it that.
                                Pretty happy with the results, car rides and drives smooth, and I'm reaping the benefits of a lightweight and strong forged wheel....
                                my M42 doesn't have to work as hard as before!
