This is a sticky topic.
  • Zacm829
    • Jan 2008
    • 1919
    #8881
    Advice on running a 255/50/16 on a et 15 16x9 wheel on rear of a flared e30? I know it is a huge diameter tire. Just trying to get the most traction possible. Also trying to put a 225/50/16 on et 20 16x 7.5 on the front of the same flared car
    1987 325i-M60b44 swap
    • Marcus33
      • Mar 2012
      • 63
      #8882
      Have a set of 16x9 klutch wheels
      Currently running 205/50/16, minor rub up front. Running firestone allseason 710s
      Looking to switch to DunlopDZ102s
      205/45/16
      I see the tread width on tire rack goes from 7.2 on firestone to 6.7 on the Dunlop DZ102
      Will this cause a massive stretch look? or will it be negligible?
      • Mystikal
        Wheel Fitment Expert
        • 9602
        #8883
        Originally posted by potatomash
        I have 30mm upfront to clear my brakes so my offsets are going to be +6 front and +8 rear. Will I get away with 215 and 235 40s with serious guard rolling and prob a bit of front camber
        Sent from my HTC One M9 using Tapatalk
        No. Not even close.
        • Mystikal
          • 9602
          #8884
          Originally posted by md-va
          From browsing through this thread, it would seem I have 3 tire size choices. I'm just not sure which one would work the best. Car is a 1992 vert lowered on Ground Control Coilovers with offset CABs. Wheels I want to eventually fix and put on are 16x7.5 ET25 all around (Racing Dynamics RGP's). From what I have read, 205/50, 215/45, or 225/45 should fit. I just wasn't sure if I would have rubbing issues with any of these tire sizes since the car is lower than stock.
          Thanks!
          Any of those. No rubbing.
          • Mystikal
            • 9602
            #8885
            Originally posted by achtung-e30
            stock ride hight early model e30 - what would it take and is it feasible ? if so a tire size would be helpful as well - thanks in advance
            30mm all around. 205/50 front 225/45 rear tires.
            • Mystikal
              • 9602
              #8886
              Originally posted by Jimmy85'E30
              I have a 87 325is. I have H&R Racesprings. I just bought 20mm 5 lug adapters as well as a set of style 5s with no tires.. What size tire can I run, this car is my daily so the last thing I want is for it to rub and I really do NOT want to have tiny STANCE tires lol.
              Too bad, they don't fit. 195/40 or 195/45 works. 205/40 will rub.
              • Mystikal
                • 9602
                #8887
                Originally posted by skuurt skuurt
                I'm cutting my fenders and putting the DTM flares on. I've ordered 15x9 with a 5 1/2 in backspace for the front and 15x10 with a 6 in backspace for the rear. I'm trying to figure out how wide of a tire I can fit on it in the rear and what will be functional in the front. This is for my turbo m52 build.
                No idea for flares, sorry.
                • Mystikal
                  • 9602
                  #8888
                  Originally posted by supkev
                  Currently have a square set of 16x8 e38 weaves "style 5" and they are redrilled to 4x100 et23 offset is the offset I believe. Sitting on Megan coilover's, I probably need to run a spacer up front. But I want to run a meatyish setup, I'm wondering if a 215-45-16 will fit and not rub? My fenders are not rolled or pulled.
                  5-8mm front spacers and none in the rear, yup those fit.
                  • Mystikal
                    • 9602
                    #8889
                    205/45/16
                    Home of the worlds largest collection of Tyre Stretch and Stance photos
                    • md-va
                      • 151
                      #8890
                      Thanks for the reply Mystikal!
                      Current: 2011 M3
                      Retired: 1986 325e, 1991 318i, 1991 325ic, 1992 325ic, 1998 528i, 2002 325xiT, 2003 530i, 2005 325xiT, 2008 335i
                      • skuurt skuurt
                        • 183
                        #8891
                        how about what tire to run on a 15x9 in the front when the rears will have a 15x10 with a 275/50r15 mounted on it?
                        1987 325 project
                        • Das Delfin
                          • Sep 2014
                          • 2293
                          #8892
                          Hi Jay. Thanks for being here after all these years. I have a question about tire size for a 16x7.5 et20 wheel.
                          I see most people run 205/45 but 205/50 has a more similar rolling diameter. Any difference in fit? Car is on H&R sports. Convertible with lower rear arches
                          Thanks!
                          • DER E30
                            • Sep 2013
                            • 2343
                            #8893
                            205/50 is perfect on a 16
                            -Christian
                            • sonomabimmers
                              • Dec 2015
                              • 802
                              #8894
                              ^^^^^ i have ran them multiple times
                              i love bmws
                              • supkev
                                • 912
                                #8895
                                Thanks for the reply!
