10mm out, 1/2" down....what happened?
    • 34844
    Originally posted by VacMan
    Spacers wouldn't, but removing the spring pads would. If he took out all 4 that's another 1/2" or more drop.
    Yes but that is not what he said. basically everything in his post was nonsense, actually.
    • Aptyp
      • 6584
      Originally posted by nando
      how the hell do spacers affect rear toe?
      I think you need to see what an E30 rear supension looks like. Also, lowering your car doesn't put more tension on the swaybar - which is called preload BTW, and you don't want any. It does affect the geometry of the sway though and make it less optimal, unless you get adjustable links. ;)
      Basic geometry actually.
      Imagine a triangle. Your base would be elongated with spacers, and sides pushed out slightly. So the top angle would increase. That angle is the tow.
        • 34844
        wow.
        toe doesn't change with track width. the only thing that changes with spacers is.. track width. the only way to change toe is to change the angle of the trailing arm - either by ride height or eccentric bushings.
        • Aptyp
          • 6584
          i need to make a drawing, but here a mental image.
          When car is lowered you automatically get toe in. Agreed?
          So now you have two lines (wheel surfaces) that at some point intersect. That is Tow, Agreed?
          If you take those 2 lines and spread them further out from each other, and have to perpendicular lines (spacer surfaces) to the original toe, toe stays the same. Agreed?
          And when you have 0 toe, spacers wouldn't make any difference at all. Agreed?
          What doesn't change equally will be the base of that triangle. Because the car is lower, your trailing arms are slightly further back. Now that base will not change any further, unless you lower/raise the car. But with spacers, the track will change. So you have 2 lines going toward the same angle from hubs and then from spacers. All 4 lines will intersect in the same spot, but the angle between spacer surfaces will be larger (toe-in).
          This ever slightly changes the toe further in. As I also said, I doubt he'd be able to feel it from inside of the car, and to read that angle you'd have to put the car on alignment tool and try both set-ups. But that does change the angle.
            • 34844
            no, no, no no no.
            "tow" is not measured from the center of both wheels. it's from the center of EACH wheel, individually.
            if you move the wheel out 10mm, the center of the wheel moves with it. "Tow" remains unchanged.
            if what you said was true, then nobody would bother with eccentric bushings or subframe modifications. we would simply add a 10mm spacer and call it a day.
            • VacMan
              • Apr 2007
              • 2405
              Ah, I see, I didn't realize you were directly replying to someone else. Just ignore me. :D
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                no, no, no no no.
                x2
                • atomic
                  • Jun 2007
                  • 5691
                  x2
                  x100
                  we win...
                  Seriously Nando is right..
                  • JGood
                    • Jan 2004
                    • 7959
                    no, no, no no no.
                    Exactly. You aren't looking at it as a triangle, you are looking at it as the angle of the tire in relation to a straight line from the front of the car to the back. That's all.
                    Toe
                    e30 restoration and V8 swap
                    24 Hours of Lemons e30 build
                    • GotCone?
                      • Jan 2008
                      • 589
                      Build : Das Drehmoment Ungeheuer
