BBS Garage: All things BBS
This is a sticky topic.
  • EndreM
    • Jul 2009
    • 513
    #1081
    Originally posted by M-technik-3
    Very odd seat, most likely made by another manufacturer for them, looks like a late 90's design. Have you sent a message to BBS? They might have an answer.
    It's made by Bertrand Faure for BBS. I see that its the same as in the E34 "Enduro" concept car.
    The guy I got them from said that they were from some concept E30 or E34.
    They are a bit big for the E30, but amazingly comfortable.
    '91 E30 316i
    '97 Rover Mini 1275
    • IronJoe
      • 2275
      #1082
      Help with offsets?
      Can anyone help me understand the offsets of my wheels? There must be something obvious that I am missing here.
      I purchased a set of four 16" BBS RS from another member:
      2x BBS RS 005 - original specs 16x7 ET11
      2x BBS RS 061 - original specs 16x8 ET20
      The way I would expect to run these would be the 005 in the front, and the 061 in the rear. HOWEVER, here's where it gets tricky. The PO of these wheels replaced all four barrels with the same size - effectively making them 16x7.5 all around. No changes to the lips.
      So my questions are:
      -How do I calculate the effective offsets for these wheels after these changes?
      -Which pair should I run in the front & rear?
      Thanks in advance all These are on what will eventually be my E30 M3 cabriolet replica.
      '89 Schwarz E30 M3 Cabriolet Build
      • getouth
        • Jan 2010
        • 3343
        #1083
        When you say replaced all four with the same size, you are not being very specific. All same size meaning the front and back have the same size barrels or the same as oem? Either way any increase or decrease in barrel size without altering lip and hub will increase or decrease et 6.5mm positively or negatively for every half inch I hope this helps.
        FEEDBACK:
        http://www.r3vlimited.com/board/showthread.php?t=316212
        BMWCCA #398608
        IG @yagayo38
        "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
        • IronJoe
          • 2275
          #1084
          Sorry, what I meant to say is that they were replaced with four identical barrels - I don't know what size barrels, but the total width of all four wheels is now 7.5"
          That is very helpful, thank you! The 005s were increased by a half inch, so would that mean instead of 11mm offset they are now 17.5mm?
          • getouth
            • Jan 2010
            • 3343
            #1085
            The opposite actually, when you increase the width you decrease the et/offset. So it would actually be 3.5
            FEEDBACK:
            BMWCCA #398608
            IG @yagayo38
            • getouth
              • Jan 2010
              • 3343
              #1086
              [emoji6]
              FEEDBACK:
              BMWCCA #398608
              IG @yagayo38
              • Idrisu
                • Jul 2015
                • 173
                #1087
                Will this require spacers to clear the caliper?
                front: bbs rs 039 16x7 et24
                rear: bbs rs 040 16x8 et24
                • c0rbin9
                  • Dec 2015
                  • 609
                  #1088
                  Anyone have a line on part #09.23.221 or part #56.24.079 center caps for BBS RZ378?
                  1991 318is Brillantrot daily driver (slow restoration)
                  • DELPHINtimecapsule
                    • Oct 2012
                    • 1468
                    #1089
                    Why not ebay?
                    • EfrenFlores
                      • Jan 2016
                      • 110
                      #1090
                      Anyone have pics of RS001 16x7.5 mounted? Im in the mood for some BBS porn pls share!
                      [/SIGPIC]
                      • Mike36
                        • 1078
                        #1091
                        RS001
                        16x8 ET14
                        16x9 ET14
                        Lower in the front now.
                        • bradnic
                          • Jul 2012
                          • 3550
                          #1092
                          Originally posted by Mike36
                          RS001
                          16x8
                          16x9
                          Gorgeous
                          How did you get 16x8 to work in front without poke?what ET?
                          HOWTOs:
                          DB vert plastic bumpers
                          OEM Keys
                          MTech1 docs
                          88 ix Lach/Card
                          91 ic Calypso 3.1
                          86 Cosmo 2.7
                          OEM+ or bust!
                          • Mike36
                            • 1078
                            #1093
                            Originally posted by bradnic
                            Gorgeous
                            ET14 both front and rear. Fits perfect without any poke ;D
                            • bradnic
                              • Jul 2012
                              • 3550
                              #1094
                              NICE. more pics please.
                              closeups?
                              please
                              please
                              HOWTOs:
                              OEM Keys
                              MTech1 docs
                              88 ix Lach/Card
                              91 ic Calypso 3.1
                              86 Cosmo 2.7
                              OEM+ or bust!
                              • Mike36
                                • 1078
                                #1095
                                closeups?
                                please
                                please
