Right before I mounted them :)
BBS Garage: All things BBS
This is a sticky topic.
NICE.. THANKS for posting the pics!!
tire sizes? spacers?
assume you had to roll the fenders and quarters for that flush fit?I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
DB vert plastic bumpers
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
e30m3s54turbo: I save my money for tuner parts.Comment
16x8 ET14 195/50/16
16x9 ET14 205/50/16
So I'm not running any spacers as that would just push out the wheels. Tire sizes are a bit tall compared to what other people run but those are all I had at the moment and they have decent tread on them. I'll probably go with 205/45/16 front and 225/45/16 rear next time. Fronts actually fit without any rolling, the rears needed a slight roll, and by "slight" I mean only needed 2mm's of clearance. I did however give them a full roll so I can run beefier tires down the road.
This photo is the rear fitment.sigpicComment
BBS RS waffle help
Hello BSS Yodas! BBS RS nube here. Need your wisdom...
I got this set of 4 16" BBS RS's at an incredible deal ($500!)
For my project
But I'm missing a centercap. The part number for the waffle is "09.24.028" but I haven't found a matching cap with that part number on CL or Ebay.
Question: Can I use another part numbers for the waffles? (Searched but couldn't find a definitive answer about part numbers)
Please advise.
Cheers!Last edited by drumsauce; 12-20-2017, 08:28 AM.Comment
Last year I found some BBS RS003 somewhat local so I went for it. Before I bought these I had been planning on buying some Nogaro Silver Euro Weaves so I decided to restore the RSs in a similar fashion.
They were in really great condition, so I decided to refinish the stock lips and not spend more on wider lips.
Refinish Process
A little color
Refinish the bolts in silver or black?
Black won
I think Dave's work, from Renewed Finishes, speaks for itself they came out amazing. https://www.instagram.com/renewedfinishes/
BBS RS003s 16x7 ET25
Original Lips and Hexs Brushed and clear powdered
Centers and Waffles - Nogaro Silver & clear powdered
Bolts and Barrels in Satin Black Powder
Wheel/Tire/Suspension
BBS RS003s - 16x7 ET25
Dunlop Direzza ZII Star Specs 225/45R16s
H&R Sports, Bilstein Sports, E90 Drop Hats, M3 Offset CABsComment
Nogaro BBS = WINI BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
That will get you pretty close to stock. I recommend a satin clear... not too glossy for the stock finish.
Sent from my iPhone using TapatalkFEEDBACK:
http://www.r3vlimited.com/board/showthread.php?t=316212
BMWCCA #398608
IG @yagayo38
"The Best E30's were built with two camshafts four cylinders and sixteen valves!".Comment
Question for all your BBS experts, which faces are the largest faces for the 17" wheels, basically the 13" center for the RS. My main problem when I had 16's was it had the 12.25 face and the bolts rubbed against my BBK even though the wheels cleared, so I had to space them further out. I know they made a 13" face but dont know which models those are.Comment
Question for all your BBS experts, which faces are the largest faces for the 17" wheels, basically the 13" center for the RS. My main problem when I had 16's was it had the 12.25 face and the bolts rubbed against my BBK even though the wheels cleared, so I had to space them further out. I know they made a 13" face but dont know which models those are.sigpicComment
I have seen that list, so I am to assume if it says 17" it has the 13" face unless it says otherwise?Comment
Having an issue with the BBS RM012. When the technician fitted the wheel onto the hub of my cabrio he said there was lots of play. Aren't these wheels and the car hub both 57.1mm? Any help is appreciated!Comment
