E30 17" wheel fitment
  • truacaldwell
    • May 2020
    • 1
    Looking at getting some 17x8 or 17x7 wheels for the 325. What is the biggest ET that can be run on an e30 without spacers? Ideally wouldn't like to be messing with spacers and rubbing arches.
    Is ET35 or ET30 to big?
  • Staszek
    • 2533
    You are in the wrong forum, you may get more responses in the wheel and tire section.
    That being said I have 17x7.5 in the rear at an ET30 with no issues. The front I have the same with 10mm spacers to clear my larger brakes, with regular E30 brakes I still probably would need spacers too.
    What are the wheels the spoke design tells clearance with for the brakes too.
    You say the biggest ET, I want to make sure you understand ET (offset). So the larger the number the closer the wheel comes to the hub (or the car). The lower the number the farther the wheel is pushed out toward the fender. So an ET10 will be much closer to the fender then an ET30. If you are at an ET30 with a 17x7 or 7.5, even a 17x8 you will have plenty of clearance at the fender (depending on tire size but you should be good).
    Your only concern at that ET will be brake clearance in the front and that's only a problem if you have like a BBS RS or similar wheel that have very flat faces and can interfere with the awkward break bracket on the E30. Some have ground it down a few MM to clear the wheel instead of using spacers.
    • Victell
      • 1083
      Originally posted by Staszek
      ...interfere with the awkward break bracket on the E30. Some have ground it down a few MM to clear the wheel instead of using spacers.
      I've heard of others grinding down the brake bracket. I didnt think this was a good idea. How much does it matter?
      • Staszek
        • 2533
        It really depends on the wheel. Grinding the bracket 2-3mm won't make much of a difference and its not the whole bracket.I think there were many people on here that did it.
        So many factors I think we need to know exacts on what wheels and sizes and what car.
        • MattWll
          • May 2020
          • 3
          17x7,5
          • digger
            • Nov 2005
            • 6182
            is 17x7.5 et25 likely gonna cause issues? i think the 16x8 Alpinas are ET28 ?
            • FredK
              • 14762
              I doubt it. Definitely not out back, more than likely not up front either. How did you even find this thread lol
              • digger
                • Nov 2005
                • 6182
                Google.
                Ok I know the kopi are ET20 so wasn’t sure. I did crunch numbers on 16x8 Alpinas so should be better than those
                I would propose 215/40 or 215/45 tyres but if I have to 205s would suffice . I think I 225/45 are too big and no one seems to have 225/40 in 17s
