NEW PRODUCT! E34 Door Reinforcement Plates!
    Does your 5ers dor "pop" when you open it? I have the fix.
    These precision laser cut door plates are designed to reinforce your door to prevent further damage, or also are good preventative maintenance.
    The plates are 10 gauge steel HRPO Grade 50 and ready for paint. They fit perfectly and only take 10 minutes or less per side to install.
    Only $22 shipped per pair - paypal me at 5toesss@gmail.com
    The install is super easy!
    Here are the tools you need: 3/8" drive ratchet, TORX T30 socket, Flat head screwdriver, hammer (I used an old ratchet) and an extension/punch.
    1. Remove the circlip from the pin on the door stop arm. I used my fingers and a screwdriver
    2. Hammer out the pin. I used a 3/8" drive extension, but a punch works great too!
    A screwdriver might be needed to get it out all the way:
    3. Remove the rubber boot and remove the two screws using a TORX T30 socket
    4. Slide the door plate and rubber boot over the arm with the noncurved side facing out.
    5. Slide the pin in very lightly to hold the arm up
    6. Align the door stop to the holes in the door. I find that if you screw in one hole as shown and push the door open hard that the door stop wont move after you remove the screw.
    Notice how my door's metal is very torn.
    7. Tighten the screws loosely and pull the plate out towards the door to align it straight.
    8. Tighten the screws all the way and slide the rubber boot on. Hook the rubber boot on the bottom and then stretch it over the top bolt
    9. Hammer the pin back in
    10. Admire your now fixed door :)
    any questions pm me!
    Would this work for e28s?
    BUY MY WHEELS! BBS E50s!!
    http://www.r3vlimited.com/board/showthread.php?t=275407
    Originally posted by Lurker27
    Any man will tell you being blown is better than being stroked.
      I dont believe so, after looking at one in the junkyard the other day.
      This plate also works on e32s
        bump!
          Any chance of this working or can you make some for the e30 mine pops :/
          Buy e30 cup holders
          http://www.r3vlimited.com/board/show...41#post4159541
          Buy BMW Motosports handles
          http://www.r3vlimited.com/board/showthread.php?t=302846
          Buy BMW MOTORSPORT valve covers http://www.r3vlimited.com/board/showthread.php?t=330146
            E30JIGZAW - I will have some e30 ones soon I will make sure to PM you man.
              Sweet thanks !! Don't forget me ahhaha
              Buy e30 cup holders
                I'd be in for this too!
                  I will make it happen guys, dont worry!
                    ttt
                      ttt
                        ttt
                          Looks like a ripoff of the ones Koala Motorsport has been making for years, albeit at half the price.
                            Ttt
                              payment sent
                              86 325e
                              92 525i
