E28 Transmission Swap from E30?
  • Northern
    I like cupcakes & sh!tboxes
    • 5237
    I have a trans from an '88 325is (P/N 23001221205) and I'm looking to put it in an '88 528e (should have P/N 23001221206)
    No 528e came from the factory with this trans P/N, but some e30s were produced using the e28's transmission P/N.
    Anyone know if it will fit/ what would need to be done to make it work?
    Originally posted by priapism
    Originally posted by shameson
  • nrubenstein
    • 3148
    It will not work. The eta engine requires bell housing mounted sensors.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • Northern
      • 5237
      Really! I would've assumed that the 5er would've switched away from motronic 1.0 the same time or earlier than the e30 did. This trans does have the castings for the sensors, so its only a matter of drilling and tapping them I guess.
      Any other reasons? I saw some threads about clutch slave depth, and some about swapping the output flange (assuming guibo size differences?)
      • ethrty
        • Nov 2009
        • 342
        driveshaft will need to be modified as will shifter. not sure about what clutch setup to use, but they are both M20 engines so should be the same. have never run into the crank position sensor issue before personally, but am aware of the issue.
        at least the bolt housing lines up with the block so from there anything is possible
        • Northern
          • 5237
          driveshaft needs to be modified because it is a large guibo and the e30 i g260 is a small guibo trans? can I swap the output flange easily? or is there a different overall length?
          • ethrty
            • Nov 2009
            • 342
            It is possible to swap depending on your skill level. however i personally wouldnt do the job. for example i have done engine and manual conversions etc before, but i would not tackle this. some things are best left to pro's, so by saying that I recommend purchasing the correct trans, or alternatively get it done professionally
            • evoe46m3
              • Mar 2006
              • 70
              What tranny is in the car right now ? Just go look at the engine. If its a m1.1 or 1.3 it will have the engine speed sensor on the timing cover and you can use the tranny. Being an 88 I would assume its a super eta which had m1.3. Its not that hard to change output flanges. I have done it before.
              probably the hardest thing is taking off the nut. If you have air tools its easy. After that you just have to use a puller.
              • Wanganstyle
                • 2828
                if e30 trans has the cast in ports for sensors than yes you can drill and tap to accomidate
                compare the bellhouse depth when you get them both side to side and make sure the 528e does not have a thicker flywheel/clutch stack and deep bellhouse; if it does just install the e30 325e flywheel with reference sensor pickups - they come in shallow bellhousing models.
                the G260 rear output flange is easily swapped with a 30mm thinwall deep socket; if you dont have one you can purchase on amazon inexpensively. mark the nut with a pain pen in a couple places and rember the drag its set at for field style swap. 325i uses a small guibo, if you can find a 325e transmission from 86/87 it will have both provisons for the flywheel reference sensors and the large guibo and provisons for both sheet metal and alloy shift carrier - my 04/87 build ETA did.
                also see if your e28 has a metal plate style shifter and if the replacement gearbox has provisions to bolt it on-
                • Northern
                  • 5237
                  Thanks for the info Wangan! This issue just came up again with another local e28.
                  • Robotin
                    • Jun 2011
                    • 4471
                    since you have an 88, which is considered a late model, the tranny will bolt up just fine.
                    you dont need to modify any driveshafts, just use the front half of whatever driveshaft has the matching guibo to your tranny. only issue i could see is that etas run off of a flywheel sensor, so you might need to convert to a late model CPS..
                    not hard at all...
                    1989 325i SETA stroker [delphin] R3V'd 8/31/2011
                    1989 325ix [zinnoberrot] $OLD
                    1970 2002 [Nevada]
                    Originally posted by Herr Faust Schinken
                    guy must have slid into something that doesn't look like a car vs car hit
                    Originally posted by ak-
                    Must of slid into Rob
