M20 3.0 stroker questions
  • Maximumtune30
    • Apr 2021
    • 15
    I plan to build a 3l stroker:
    M54b30 crank 135mm h beam rods
    Custom pistons (85mm)
    Oversize +1mm valves, schrick valve springs, Hd rockers
    What compression pistons should i choose? (We have 98 octane fuel here in finland)
    What cam to match the compression ratio and i would like the peek power to be around 6500-7000rpm.
    Will a catcams 299 or 302 be too much for 10.5comp?
    Will the m54 crank fit straight in or is some kind of adapter needed?
    • 34844
    You should look for digger's 3.0 stroker thread. it probably answers all of those questions and more. it's long but probably worth it if you're building an M20 in 2021.
    • digger
      • Nov 2005
      • 6198
      11:1 CR OE dish dome
      ENEM Z54 cam (296 degree 106 LSA ) ,
      RHD ITB
      standalone ECU
      nice header and exhaust
      will be a good combo on 98 RON to peak at 7000rpm. probably not the best for a daily driver more of weekend car that occasionally driven to shops
      not sure the schrick springs will be up to the job, a 288 duration is probably the biggest they will accommodate
      like all M5x or S5x (US) from e36/e46 they need an oil sleeve, longer crank bolt and modified washer for the crank bolt (all simple mods you can buy)
      Molnar H beam rods are your best bet for aftermarket (S5x rods etc are ok to) as they are pretty compact and wont need to hack the inside of block to fit it in like some other beefy H-beams that are completely unnecessary for a NA m20
