M20b25 build with 2.7 block ???&@
  • Amelbmw@aol.com
    • Mar 2019
    • 10
    I just want get honest opinion from you guys
    I decided to put bigger cam 274 with heavy duty springs that I purchased from bummerheads
    when I take head out and take to mashin shop I discover my crank is wore out
    now I can order new crank with new bearings but my friend have m20 from E car and suggested go used block from 2.7 and put my head off I car
    i really want keep stuck much is I can but I don’t have no idea is this good move but I am already there
    I am pretty sure someone did this
    any suggestions is going be appreciate
  • McGyver
    • 4637
    Go read in the m20 section.
    In short, putting an 885 head on a stock 2.7 bottom end is not a good idea. You may get a little more torque in some area, but it's a horrible combination of parts. Either have the crank ground and use the next oversize bearings, or look into building a 2.7i engine. Or call Bimmerheads and ask them for a suggestion.
    • Reichart12
      • Aug 2012
      • 2165
      Block dimensions are the same but the rotating assembly is different on the m20b25 vs m20b27.
      Instagram: Reichart12
      • digger
        • Nov 2005
        • 6195
        Get the 2.7L 81 mm crank and 130 mm rods and combined with your m20b25 pistons. shove this into your m20b25 block but deck the block around ~2 mm so the piston doesn't sit so far down the bore when at TDC. Add an adjustable cam get and you have a decent CR 2.7L with mild cam and it would be a nice combo
        simply putting your cammed 885 onto an eta will lead to less improvement than people think
        otherwise just find a good m20b25 crank and reassemble your block or a good used short block
        • Amelbmw@aol.com
          • Mar 2019
          • 10
          Thank you everyone for replying !!!!!
          evidenly my body just want sell me his block telling me story’s but list is low miles engine and $300(((
          I really don’t try to get any more power or going race /drift or any......
          my goal is just get few extra power mainly some rumble longer don’t go any slower
          but I got some thinking to do
          • Amelbmw@aol.com
            • Mar 2019
            • 10
            Update
            I completed this built and so far I am pleased with
            maybe this is cheap way to build but after I install bigger injectors and did chip from ssdquid it just did fine
            budget built but is good …. Lol
            • 2mAn
              Señior Mod
              • 21006
              Congrats on getting it built!
              You should start a thread in the "members rides" section with pics of the engine build and the car itself.
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              Make R3V Great Again -2020
              • Amelbmw@aol.com
                • Mar 2019
                • 10
                • Amelbmw@aol.com
                  • Mar 2019
                  • 10
                  Can’t upload any pictures it is always something to big or …,
