Milling 885 for eta
  • Woodgear
    • Jun 2021
    • 15
    Milling 885 for eta
    Welp, my first post has been a long time coming. Hope I don't cry myself to sleep tonight when this is all over.
    I've read quite a bit about this and am in a bit of a time crunch.
    My eta is stock for now. I have all the bits I need for a 731 head swap, but after a few days at the machine shop that head has proven to be a money pit. I'm inclined to pump the brakes on it before I'm in too deep and use a friend's 885 head.
    My hope is to keep it na, put a Bimmerheads 274 in it, and get a sssquid chip.
    My question is how much can I safely mill this 885 head?
    I realize thus question has likely been posed verbatim at some point, but I have looked. Really hoping I just get a response that say .040" or something easy lime that. But, I'm a realist and know that this might sting a bit more.
    Thanks in advance for any guidance and for this fantastic site.
  • lukeADE335i
    • Apr 2013
    • 1389
    There's a thread about 8 posts down in this General Forum on this exact topic. Anyway - I'll quote Digger from there to save you looking:
    Originally posted by digger
    Get the 2.7L 81 mm crank and 130 mm rods and combined with your m20b25 pistons. shove this into your m20b25 block but deck the block around ~2 mm so the piston doesn't sit so far down the bore when at TDC. Add an adjustable cam get and you have a decent CR 2.7L with mild cam and it would be a nice combo
    simply putting your cammed 885 onto an eta will lead to less improvement than people think
    otherwise just find a good m20b25 crank and reassemble your block or a good used short block
    You'll be looking to do the same thing, but while you're grabbing your friend's head, grab his M20B25 pistons too, or buy a new set.
    I'd just use the 731 head, they actually flow pretty well and you can use a stock ETA bottom end.
    My e30: OEM+ with M30B35
    • Woodgear
      • Jun 2021
      • 15
      Thanks. I have read all that and am trying to avoid getting into the bottom end. I'll likely opt for the 731 at this point. I was kind of excited about running that head to begin with. It just needs a bit more work.
      • digger
        • Nov 2005
        • 6199
        I wouldn’t deck the 885 and “ruin” it
        • Woodgear
          • Jun 2021
          • 15
          Gotcha. I will leave it alone and work with the 731. Thanks for your input.
          • 2mAn
            Señior Mod
            • 21049
            Throw the cam on the 731 with new hardware and just save up to build a proper M20 down the road
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            Make R3V Great Again -2020
            • MrBurgundy
              R3V Degenerate
              • Mar 2012
              • 5604
              Why is the 731 a money pit
              • 2mAn
                Señior Mod
                • 21049
                885 head has larger ports and bigger valves, so it makes more sense to start there.
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                • digger
                  • Nov 2005
                  • 6199
                  because in stock form it is barely better than the ETA, to properly port a head with bigger b25 valves, probably new guides is laborious on any head and even then its only just capable of feeding a 2.7L as well as 885. it ends up being a more expensive exercise than the 885 head but the chamber matches properly so sticking with the eta/flattop piston it is what it is.
                  Most 731 don't deliver what the hype says IMO (with exception of Rama's old 43mm head and his newer 44mm valved head which is miles away from the average 731 head swap )
                  • Woodgear
                    • Jun 2021
                    • 15
                    Well, mine in particular has a poorly repaired crack on one of the rocker shaft guides and some bad corrosion on one of the exhaust ports. I'm still going to add a 274 cam go with it though. Should be education the hard way for me.
                    New rockers necessary?
                    • jeffnhiscars
                      • Jun 2011
                      • 6011
                      Having done this very mod I wouldn't do it any other way if you not going turbo or doing the bottom end. Yes it costs but it's pay to play. We did the guides, +2 valves, IE272, refaced the rockers, replaced the eccentrics, mildly ported according to Rama's guidance, then for good measure did a motronic upgrade w 19lb injectors and a full 2.5 exhaust.
                      Alice the Time Capsule
                      • lukeADE335i
                        • Apr 2013
                        • 1389
                        This was why I went for my M30 swap - was all set to do a 2.7L build back in the day, then decided it just wasn't worth it over the high compression / ported head 2.3L I already had at the time, which with a 3.9 diff was plenty of fun and not that far behind a M20B25 hp wise. The 2.7 was only going to yield slightly more hp and a bit more torque.
                        M30B35 has all the upgrades the M20B25 has, and an extra litre of displacement. Still - it has turned into an expensive swap now. Back then e28s, e32s and e34s were abundant at the wreckers.
                        • Woodgear
                          • Jun 2021
                          • 15
                          I've always dreamed of an m30 swap, but it will have to wait. I have my 731 head back from the machine shop and a cam is in the mail. Along with my newly acquired 3.73 lsd I imagine it will before enough of an improvement for me to be able to focus on other bits of the car that need help. I reckon 19# injectors are in order as well?
                          Thanks again for all the insight folks.
                          • digger
                            • Nov 2005
                            • 6199
                            Did you ever do a power run to see the improvement ?
                            • jeffnhiscars
                              • Jun 2011
                              • 6011
                              I did not...butt dyno though tells me it's significant.
