Spark plug wires
  • Kavadarci
    • May 2021
    • 59
    Spark plug wires
    Hi, what are good set of wires for 89 M20?
    Rock auto have few variations attached:
  • McGyver
    • 4637
    I would get Bosch or Bremi (maybe Karlyn), not some cheap alternative. Buy once, cry once, and don't worry about your ignition system for the next 30 years.
    If you're getting plugs, I've had bad experiences with Bosch (WR8LC+) and will only use NGK (ZGR5A) at this point for the e30
    Blunttech Bremi
    ECS Options:
    https://www.ecstuning.com/BMW-E30-32...rk_Plug_Wires/
    • Vincenze
      • Apr 2019
      • 1034
      NGK wires are blue.
      • Kavadarci
        • May 2021
        • 59
        Blunttech Bremi
        ECS Options:
        I have Bosch W8LCR nickel in the shopping cart. What kind of issues you had with the + version?
        the only ngk are ZGR5AGP G-power
        bosh are nickel ngk are platinum
        • Vincenze
          • Apr 2019
          • 1034
          The NGK ZGR5A has the nickel electrodes.
          Platinum NGKs will be more expensive.
          https://www.ngk.com/ngk-5077-zgr5a-v-power-spark-plug
          It works, you just unscrew the tip.
          • McGyver
            • 4637
            Premature failure of the plugs, specifically hairline fracturs in the ceramic causing intermittent misfires. It's happened on two sets that I've bought recently, one for my '91 325i and then another set for my '89 325i. Both were only a year or two old with less than 10k miles on them.
            Maybe it's bad luck, maybe its getting tossed around too much in shipping. I've never had problems with NGK, so that's what I've switched to.
