E30 weird noise after stage 3 clutch install , is this normal or is something wrong ?
  • Obito22
    • Mar 2023
    • 50
    So I recently installed a stage 3 clutch alone with a aluminum single mass flywheel and I replaced both the pilot and throwout bearing and I made sure to add grease to the throwout bearing , now that I think about I might have gotten a bit of grease from my hands on the contact surface of the bearing but anyway I got the car all back together and it started up fine but only one issue whenever I press the clutch in it makes this weird noise almost like a grinding noise , I’ll add a video below but it only does it when the clutch is pressed in and if I put in gear while being stationary with the clutch in it still makes the noise and when I drove it it would also make the noise in between gear changes. Now I’ve never had a stage 3 clutch on my car but I am pretty sure that’s not normal right ? Anyway I couldn’t upload the video so I had to post it on YouTube here is the link . You can see when I press the clutch in the noise will start . I haven’t drove the car since because I want tu be sure and not risk damaging anything anymore if I already did
    Sorry I forgot to smack the top of my dash lol
  • TobyB
    • 5222
    Your video is private.
    But yeah, noise when depressing the clutch isn't right.
    New throwout bearing? RIGHT throwout bearing?
    You CAN get a bit of a 'zizzz' sound right as it engages,
    as you let off the pedal, from the radial surface grinding texture on the flywheel and pressure plate.
    t
    • Obito22
      • Mar 2023
      • 50
      Sorry it’s not private anymore TobyB
      • Jaxx_
        • Dec 2009
        • 1880
        It does seem like a throwout bearing issue. I also wonder about the pivot and if it happened to be greased or replaced when you put it back together. I think generally a squeak from the pivot would happen in the opposite case, but also worth investigating.
        I don't know if there is much else that would cause this problem. I would consider pulling the transmission off and inspecting (at least) or replacing the throw out bearing. Inspecting the fork for bends, grease the pivot, etc. I think it is possible to incorrectly orient the throw out bearing, but I think you'd have other problems too.
