ECU 18 MPH problem
  • Brixk
    • Jan 2024
    • 4
    ECU 18 MPH problem
    Car wouldn’t pass BAR, it’s a completely stock S50 in a 318is When the ref plugged in a scanner to see live data, it showed the car was traveling 18mph while at idle, the speedo reads right, what would be causing this issue?
  • prisonerofdoom83
    • May 2013
    • 529
    I had this same issue your dme is probably from an automatic . Same thing happened to me so I had to buy a manual dme and then he passed it . He also made me have the glovebox taken apart so he could see the dme part number and vin
    • Brixk
      • Jan 2024
      • 4
      I searched up the vin and the car it came from was a manual, i’ll call bmw in the morning just to confirm. In the case that it is a manual ecu, is there anything else that would effect speed that the ecu is seeing?
      • 82eye
        • Jan 2009
        • 2099
        no. not without the wheels turning.
        • prisonerofdoom83
          • May 2013
          • 529
          Did they do the sniffer test? Mine was reading high with the auto dme also . Then the manual dme made the emissions come down also . 🤷🏻‍♂️🤷🏻‍♂️
          a fresh oil change helps the emissions go lower and hot cats
          • Brixk
            • Jan 2024
            • 4
            so I called bmw to decide the vin and turns out the ecu is in fact from a manual car.
            as for the sniffer test, I did change the oil (5w-40 castrol euro) a week prior and the car burns SUPERR clean, so there was no issues smog/emissions wise. although the car could benefit from a new 02 as the scanner also read that the 02 was staying at .4v and not fluctuating.
            • prisonerofdoom83
              • May 2013
              • 529
              Hmmm I’m not sure then . I failed because of the dme the first time . Then changed the dme and passed the second time . Luckily that was my only correction . The tech told me don’t worry no one passes the first try although I was very close . Good luck!! When they pass you and you pay the sticker fee is a great feeling
              • Brixk
                • Jan 2024
                • 4
                I can’t wait for that feeling, just have to figure this little hiccup first, it’s completely throwing me for a loop.
